autox tire pressures
Old 08-20-2006, 10:11 AM
Rich427
Rich427's Avatar
Default autox tire pressures
I have a '01 6 speed vert that I occassionally run (2 - 4 times a year) an NCCC autox. The car is basically stock and I run in the 1SH class. I just recently got rid of the run flats and changed to Goodyear GS D3s for everyday tires. Can someone recommend tire pressures front/rear for this tire. Our club is doing a Corvette/Porsche challenge in a couple of weeks on an asphalt parking lot. The Porsche guys have gotten the lot and will be setting up the track, so I expect it will be tight with not a lot of areas to exercise the horsepower.
Any help for the tire setup would be appreciated.
Thanks in advance!
Rich
Old 08-20-2006, 12:10 PM
TedDBere
TedDBere's Avatar
When I run GSD3s I run 40 lbs front and 36 lbs rear. Good luck.
Old 08-20-2006, 10:23 PM
Rich427
Rich427's Avatar
Thanks Mr. DBere!
That at least gives me a starting point and I can adjust off of those pressures after each run.
To autox tire pressures
Quick Reply: autox tire pressures
