Is my PCV bad again or do I just need a catch can... oil in maifold, thin coating.
Old 08-23-2006, 12:04 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Is my PCV bad again or do I just need a catch can... oil in maifold, thin coating.
http://forums.corvetteforum.com/show....php?t=1479611
I'd like the input from fellow track nuts who see high rpms often.
Old 08-23-2006, 07:58 AM
Axelrod
Axelrod's Avatar
The pcv system is just that-- Positive crankcase ventilation. What causes excess oil in the top end? Many things.... excessive ring blow-by (compression/leak down tests req'd), wrong restriction in block to head oil galleys (verry uncommon), over filling the crankcase (aka oil pan-- verrrry common)
Is the upper end pcv unaltered? More info req'd....
Old 08-23-2006, 08:56 AM
Cobra4B
Cobra4B's Avatar
No upper end PCV is factory LS6... It's probably from the 1 quart overfill when I run HPDEs.
Old 08-23-2006, 10:12 AM
XPC5R
XPC5R's Avatar
No way to keep the oil out short of a full PCV delete. If it is just a light mist, then no real problem. If you have puddles, then its an issue.
Old 08-23-2006, 10:44 AM
Cobra4B
Cobra4B's Avatar
^ It's just a thin coating, nothing crazy. Just now that I have it appart wondering what I can do to make it better.
I'll just get a nice catch can for the valley cover PCV line.
To Is my PCV bad again or do I just need a catch can... oil in maifold, thin coating.
Quick Reply: Is my PCV bad again or do I just need a catch can... oil in maifold, thin coating.
