sliders and rails.......
I just bought my Sparco EVO from a board member on here. Where can I buy the sliders and rails to mount these in my 02 Z-06?? Are there some better than others?? Thanks for your help.
Sparco's make a slider that will work, but the problem is that its not made for our car, the slider track grinds on the inside of the seatbelt return, but it does work.
The other option is to run a hardbar seat mount that will fit perfect, and lower the overall height "which is good IMO", but you loose the ability to move the seat front to back.
Hope this helps.
Hope this helps.
1 Post
Cruise-In II Veteran
Originally Posted by freefall
hardbar makes a nice product - excellent customer service also.
The issue with sliders are they cost real estate either in width or height, both are in short supply in a Corvette. Also they all will have some slop one way or another. Ours are very adjustable, but in a bolt in way and include the CNC machined adapters that are required in C6's and C6's due to the short studs that sit in a "crater" in the floor. Our rails are race proven and were used in the Phoenix prepared C5 that was driven by John Heinricy to last years' T1 National Champoinship.
Available for C4, C5, C6, and C6Z, $300 plus shipping.
Originally Posted by ghoffman
Thanks!
After using some modified stock slider seat rails for several years and being happy with them (I thought), I called Gary and he sent me his new, light solid mounting system. There's just no comparison. Nothing moves - rock solid and I am able to sit about 1 to 2 inches lower than before (lower Center of Gravity is good). It also saved me about 6 lbs so that was a benefit too.
To go fast, improve the contact patches first. Anything that touches something else, improve it and you'll go faster - Tires, Brakes, rotors, seat, harness, MOUNTS, gloves, shoes, suit, etc.
Bottom line - It's well worth the money!!! I'm the king of the budget racers and this is "cheap speed" man!!
Originally Posted by 2000BSME
Excuse me please, but if I am reading this correctly, when I buy my new racing seat(s) for $500-$1000, I will also need a $300 piece of mounting hardware for each (both?)?
I thought ATI Performance Engineering made adapters to mount Sparco seats to the stock rails. I can't find them on their web site though. It might be worth a call.
Hardbar is a supporting vendor of this forum (I think) and Gary's number is: 603.682.8073 or 488.5573.
Phoenix Performance uses his stuff exclusively so you know it's good.
1 Post
Thanks! I supply Phoenix for the Vettes and Vipers as well as a slew of others. I hired a web company to get that site up soon, sorry for the inconvienence. They are available for C4-C6 and Viper. Just call me at 603-682-8073
Cheers,
Gary
Cheers,
Gary
