PFADT Coilovers - anyone tried them
I have the Pfadt coilovers, along with the sway bars on my 2000 Coupe. The ride on the street is much better than the z51 or z06 setup (I've had both on the car). The car doesn't skip or do strange things anymore when hitting rough pavement in a turn at speed. On ramps are great, no wheel hop, and the nose dives a lot less under hard braking. On the track, the difference is just as great. The car is glued to the corners. I run with the Porsche club at Miller Motorsports in Utah, the Corvette will gain ground on a new GT3 in the tight sections! I run Toyo RA1's at full tread depth on track and off, they were on shaved race tires. The adustability is nice, too.
1 Post
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
I'm not going to put words in anyones mouth, but ask over on DigitalCorvettes. There are a bunch of people over there who have them on their cars.
-Aaron
-Aaron
1 Post
Cruise-In II Veteran
Your sway bars look really, really, nice, congrats! Have you tested them on a C6Z yet? Can you adjust the Heims without removing them off the bars?
How about some details on your coilovers like: how you adjust them, rebuild/revalve services etc?
I hate to say this but I hope you are not the one driving in the video, that person has alot of very bad driving habits!
1 Post
St. Jude Donor '08
Aaron,
I'm debating going the T1-swaybars route but I'm intrigued about your sways...they look like very nice pieces. What are the relative stiffnesses of the different positions? I have a 2002 Z06 that I autox and trackday...and daily drive to work.
So...how stiff can they get?
Thanks,
ace
Thanks,
ace
Former Vendor
1 Post
Originally Posted by ace996
Aaron,
Thanks,
ace
Thanks,
ace
Location: If you don't weigh in you don't wrestle Road America
Originally Posted by C5stein
With this bar you can soften it up for the street and stiffen them up for the track. Your car's handling will be more adjustable for your driving style with these bars as well.
1 Post
St. Jude Donor '08
Aaron,
Thanks,
ace
Thanks,
ace
Sorry for the late return to this post. Here is my standard spiel about stiffess. Probably should post this on my website. Let's assume the C5 Z06 sways are a 1. Our sways are a 1.5 nominal. They really adjust around that number. There is more room for adjustabilty in the rear, so the range is larger there. The adjustment is about 20% in the front and 40% in the rear. The length of the lever arm (what we adjust) has a linear relationship to stiffness. The T1 bars are about a 3. They are really stiff. They may work well in a certain setup, but not for most. We are building a set of our bars that approach T1 stiffness for dedicated track cars. They will be called Pfatty bars. I have a few people running them right now and should have a small production batch in a week or so.
For your situation, I would go with our standard bars. You can dial out that understeer you have and pick up some roll stiffness without killing the ride of the car.
Hope this helps. Call or write if you have any other questions.
-Aaron
1 Post
St. Jude Donor '08
Originally Posted by 96CollectorSport
How exactly does the bar get softer or stiffer. Do you change the mount point from one of the 3 holes on the arm? Or do you move the arm on the bar itself?
-Aaron
