Welding worries.
Old 09-06-2006, 12:30 AM
danswofford
danswofford's Avatar
Default Welding worries.
I'm welding in a 4 pt. Should I pull the ECU/PCM? I know that some muffler shops weld on anything no worries, some shops clip some kind of jumper on the battery and some Corvette guys say pull the chip first. Any thoughts? And if I should pull it, where is it and how do I do it.
Old 09-06-2006, 07:19 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Play it safe, disconect the computers. After seeing one of the local shops fry one in a botched welding attempt on a roll bar install, it's the safe thing to do. It's time and safety VS $. Check out the price of a new or used computer.
CHJ In Virginia
Old 09-06-2006, 07:20 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
http://z06vette.com/forums/showthread.php?t=79099
keep ground as close to where your welding as possible.
Old 09-06-2006, 10:02 AM
XPC5R
XPC5R's Avatar
Disconnect the battery (both terminals), and you will be fine. The computer is not grounded via it's housing. I weld on the race car all the time, but the battery is disconnected via a kill switch before I start.
I'd be a bit more worried about the fuel tank or it's crossover line myself, depending on where the feet of the main hoop land.
Old 09-06-2006, 10:36 AM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
take out the tanks on a C-5!!! i melted holes in mine ,was just luck it didn't catch fire!!
johnny
Old 09-06-2006, 11:07 AM
danswofford
I'm taking the gas tanks out.
Thanks for the info on the battery.
Old 09-06-2006, 11:34 AM
XPC5R
XPC5R's Avatar
Sounds good
To Welding worries.
Quick Reply: Welding worries.
