Any of you who've changed valve springs or worked on motors... input?
Old 09-07-2006, 03:09 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Any of you who've changed valve springs or worked on motors... input?
http://forums.corvetteforum.com/show....php?t=1492859
Old 09-07-2006, 07:04 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Being an exhaust valve, I'm thinking the edge is burnt and cracked. A chunk let loose doing the spring swap. either way if you can't get a borescope to see what's down in the cylinder, I'd pull the head and see what's up before further damage occurs.
Old 09-07-2006, 07:09 PM
Cobra4B
Cobra4B's Avatar
Rubber mallet fixed it... letting it seat under spring pressure =)
Old 09-07-2006, 09:23 PM
Miaugi
Miaugi's Avatar
Old 09-08-2006, 07:05 AM
varkwso
varkwso's Avatar
Never underestimate the power of a good hammer!
Old 09-08-2006, 01:41 PM
XPC5R
XPC5R's Avatar
To Any of you who've changed valve springs or worked on motors... input?
Quick Reply: Any of you who've changed valve springs or worked on motors... input?
