allignment
I'm running that setup.
I've got 12,000 miles on the car and about 25 miles of it is autox. Since I spend a lot more time on the street than at autox or track days I've gone with about -1.3 in the F and -.8 in the R & zero toe. -1.5 F & -.9 R is about max if it's a daily driver IMO. You can screw a little toe out in F when you change to race tires very easily.
Have fun.
For DIY alignment see http://www.metricchemical.com/align.PDF
Have fun.
My C6 Z51 that does autox/track duties on the stock Supercars is -1.1 F / -0.9 R with a little toe-out in front, and a little toe-in in back. Probably near 5000 miles now, 300 (?) track miles, and 4 days of 5 runs/day autox?
1 Post
Cruise-In II Veteran
You don't need any luck, you just need the right tools and a little experience (and good instructions!). Eventually everyone who does track events or Auto-X ends up doing it themselves because there is no such thing as a compromise setup. Why waste your tires on the street and track with a setup that is slower at the track, and cooks your tires on the street?
FYI, did you see this?
http://forums.corvetteforum.com/show....php?t=1459397
But it's really the camber I'd like to change between every day driving and the track.
PS- Don't let me put another order through without including your camber locks/plates and the alignment tool... what's involved in installing the camber pieces?
1 Post
Yes, true, but whenever you change camber, you have to reset the toe. I'll email you the instructions for both.
Thanks again,
Gary
