c5 zo6 5 point
Old 09-11-2006, 10:34 PM
TRACKMAN2
TRACKMAN2's Avatar
Default c5 zo6 5 point
where doe you guys bolt your lap belts to the door side is burried and the shifter side bolts to the seat?
Old 09-11-2006, 10:38 PM
gkmccready
gkmccready's Avatar
http://www.hardbarusa.com/page_options.htm
"Lap Belt Crossbar"
Old 09-11-2006, 10:49 PM
TRACKMAN2
TRACKMAN2's Avatar
Originally Posted by gkmccready
a lightbulb just apeared over my head. welder grinder he i come....
Old 09-11-2006, 10:56 PM
gkmccready
gkmccready's Avatar
Not sure the time/effort is worth it when you look at Gary's stuff... his crossbar works with his seat mounts which works with his harness bar which ... it's all tested and easy to install.
Old 09-12-2006, 01:20 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Brey-Kraus lap belt mounting hardware:
http://www.bkauto.com/corvette/index.php
Old 09-12-2006, 08:15 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I use these and they are easy to install and work great. you also get the benefit of 6pt...
To c5 zo6 5 point
Quick Reply: c5 zo6 5 point
