2007 Z06 Rotor Question
Old 09-15-2006, 08:36 AM
darrahc
darrahc's Avatar
Default 2007 Z06 Rotor Question
Guys:
Apologize for asking a 'newbie' question but I guess everyone has to start somewhere...
What is the rotor size or part numbers for the NAPA rotors that I should get to fit the '06/'07 Z06? I tried to do a search on this and am sure it's buried somewhere but was unable to find my answer
Also, am I correct in assuming that this is relatively simple thing to do yourself? I haven't done it before so anything in particular to keep in mind? I've read a couple of the other threads on changing rotors and it seems relatively straight forward. So I'm encouraged that I can do this myself without having to take it somewhere everytime to do it.
Thanks.
Old 09-15-2006, 08:42 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,386 Likes on 742 Posts
I don't think you're going to find non-GM vendors selling OEM C6Z06 rotors yet (if ever).
If I ever get a C6Z06 I'll probably change out the front brakes anyway.
Have a good one,
Mike
Old 09-15-2006, 09:04 AM
darrahc
darrahc's Avatar
Just to clarify, I'm looking for recommended rotors for HPDEs. In the C5 sticky the part numbers for the NAPA rotors are 86700, 86701, 86702, 86703. Are these the same ones for the Z06 or are there different ones?
Old 09-15-2006, 09:06 AM
UstaB-GS549
UstaB-GS549's Avatar
The C5 rotors ate 12.9" Diameter. C6 are 14".
Old 09-15-2006, 09:10 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Hardbar.net has some two piece rotors but they are more than NAPA's
Old 09-15-2006, 09:11 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
The stock rotors and calipers are the worst part of the otherwise fantastic car. The rotors are 26 pounds each, have the worse than worthless holes that eat your thin expensive pads, and are only left sides. We offer an alternative that are 16 pounds each, heat treated and balanced, made in USA, and work with the stock calipers or the new PFc zr33 Grand-Am caliper.
Stock wheels, stock caliper, new rotor:
PFC zR33 caliper with new rotors (they fit the stock wheels too)
Gary Hoffman
hardbarusa.com
603-682-8073
Old 09-15-2006, 10:27 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
If your looking for rotors other than stock Livernois Motorsports also has Brembo rotors availible, pricing is listed as **Call** but here is the link.
http://www.livermoreperformance.com/...ke_rotors.html
Just another option, they also have a listing for DBA (Disc Brakes Australia) who I think make the rotors for the C6 Z not sure if they could find some non-drilled rotors or not, they don't have them listed but that doesn't mean they dont exist.
Although I'm guessing your not going to find a better deal on rotors than Gary at Hardbar!
To 2007 Z06 Rotor Question
Quick Reply: 2007 Z06 Rotor Question
