Tapping after DE weekend
I have a 2000 C5. I was at the Cresson, TX MSR DE event. The car ran fine all weekend. However, a hollow metallic tapping occurred when I started the car to take it off the trailer at home Sunday evening. A few days later I took the car to my local mechanic and the tapping disappeared.
He suspects it was a collapsed lifter.
Has this happened to others? Anything I should look for or actions I should take to avoid future damage?
Thanks in advance for your help.
John
John
John
John
Joe
Thank you!
Thanks you both for your replies.
I did miss a shift at the previous event which is probably where it started. The car was also run hard and then parked directly on the trailer after the last session. I normally let it cool down at idle for a few minutes before shutting it off.
I'll keep an eye (and ear) in it and see where it goes from here.
John
John
