How do 2004 ZO6 brakes differ from 98 C5 brakes?
After my car crudded out on me yesterday a freind of mine let me finish my runs in his 04 ZO6.
His brakes are MUCH better than mine... Like so much better I littterally found myseld stopped on course Before I got to the turn.
I run autozone purchased PFZ pads. And I have front brake calipers on the rear (and on front).
So what is making the big difference?
Originally Posted by freefall
What's his setup?
Different ABS and electronic brake bias control (and cornering brake control too I think). Also pad compound was more aggressive. That's about it, the calipers, rotors, and master cylinder are all the same.
Also, in many cases, a car with a soft suspension (like a stock Z) and shocks will brake harder, because the slow weight transfer to the front won't set the ABS into ice mode like a stiff suspension will.
I meant he has stock brakes.
Should I be running stock zo6 brake compound pads?
Also, is there any way I could upgrade to the different ABS/biase control?
I just couldn't believe how much better his brakes were than mine.
What kind of tires are you and your friend running? There shouldn't be that much of a difference in braking.
The stock Z06 pads are definitely no slouch. I think that they are better than a lot of street/track compounds that you find on the market like the Hawk HPS. I remember running the stock pads at the track with just a fluid change and they weren't bad at all.
The stock Z06 pads get a bad rep because the waxers don't like that they dust up their wheels.
We both run 710s. He has 315/335 staggered and I run 315s all the way around.
I'm talking about a BIG difference in braking.
If you (or anyone) wants a set of stock Z brakes, I have a set off of my car that only had about 500 street miles so they are basically brand new - $200 for the full set! If you want even more performance, call Chris, Dan or Matt at Carbotech and upgrade to the XP series of pads. XP10s on front is a good starting point. You'll be able to brake very, very well then!
"Autozone" PFC pads sound a little sketchy to me.
Have a good one,
Mike
Originally Posted by VetteDrmr
He's referring to the PFC Z-rated pads, which are much, MUCH better than the PFC OE replacements.
Have a good one,
Mike
Have a good one,
Mike
My head is consummed with thoughts of replacing transmissions today... I run the PFC-Z pads that you can buy at autozone..
Originally Posted by gkmccready
Not sure why nobody is mentioning this, so maybe I'm way out in left field, but won't the front calipers on the rear change the bias significantly potentially making the braking worse rather than better?
You increased the piston size / volume in the rear with the front calipers. So now you now need more volume in the master which you don't have so your brakes are spongy and the bias is off. JMHO His brakes probably feel like old time power brakes compared to yours.
OEM master cyl?
I didn't think about that. I don't know why you need front calipers on the rear when you're running stock calipers up front. Like others have said, you may be overpowering the braking system if you're running the OE master cylinder and that could be taking away from the efficiency of the front brakes which do most of the stopping for you anyway.
Cruise-In III Veteran
Originally Posted by Aquaman
oh, oh, oh, oh, I know why. Because though it may feel a bit mushy, RAFT's stop fast, and rotate well!
oh oh oh soooo true.
OK guys let's just forget saying that its because the fronts are in the rear. Cause when I switched the fronts to the rear the car stopped a LOT better.
What does it mean to Glaze (sp) your brakes? And how does one "un-glaze" ones brakes if the formentioned had in fact occured.
For the glaze, replace the rotors and pads. For more braking power, replace the pads - Wilwoods (H) are pricey, but they are very powerful (high cf). I changed to the H compound from a street type compound (E) and it was night and day.
Me scratches my head because there shouldn't be a BIG difference if you're both running the same tires. Have you tried different pads on your car? "Autozone" PFC pads sound a little sketchy to me.
