C3 Suspension tuning advice
New to this particular Forum...
I have a '69 big block 'vert that has had the Vette Brakes suspension kit installed by the previous owner. Think it was the 'Slalom' version of about 6 years or so ago.
Anyway when I am driving somewhat aggressively on an on ramp cloverleaf (maybe about 55mph) I notice that when I let off the gas the front end keeps turning in but seems to increase the radius. Or I guess the rear end may be coming around a bit. It is a bit scary actually. If I accelerate again it stops doing it.
I was wondering if the set up can be adjusted to 'back out' some of this off throttle reaction.
I know the older Porsches had this issue but wasn't aware a heavy front engined car could also have it.
Any advice appreciated.
Regards, Mark
Regards, Mark
when you let off the gas you are loading up the front tires and lifting the rear. That is the quickest way to loose it in a turn, all cars/bikes will do it, more easier than others. Use the throttle to turn the car.
Some advice, go to a track and try it out, not a public road.
THX
THX
THX
THX
If your car is "pushing" you can play with the tire pressure also, lower the fronts 2-3 pounds that and throttle steering should do it for you. Try to find an autocross great oppurtunity to experiment with tire pressures. If you don't care to replace tires you can do some alignment work on it too.
Laurie
What kind of shocks, and what's your alignment settings (front and rear)?
