'07 C6 Z51 Scale/Alignment results
Old 10-02-2006, 09:03 PM
M_Minnick
M_Minnick's Avatar
Default '07 C6 Z51 Scale/Alignment results
In preparation for upcoming HPDE's and to correct the factory alignment, I had a local race chassis shop scale and align my 2007 C6 Z51.
The results were:
LF RF
907 840
LR RR
888 835
Cross Weight ended up at 50.1/49.9% from a starting point of 46.8/53.2%.
The final alignment settings were -1.3/-0.9 Camber F/R, 7 Caster, and +1/8"/-1/16" Toe F/R.
Mike
Old 10-02-2006, 09:35 PM
96GS#007
96GS#007's Avatar
Received 1,739 Likes on 1,047 Posts
Originally Posted by M_Minnick
The final alignment settings were -1.3/0.9 Camber F/R, 7 Caster, and +1/8"/-1/16" Toe F/R.
Mike
The rear camber of 0.9 is ugly. If it's -0.9 although you'll find that those settings are still pretty mild.
Have fun
Old 10-03-2006, 04:41 PM
gkmccready
gkmccready's Avatar
I'm -1.1 F / -0.9 R on my '06 Z51 ... it may be mild but it works pretty well on the stock Supercars...
Old 10-03-2006, 06:26 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Nice to have a direct C6 Z51 versus C6 ZO6 comparo:
Old 10-03-2006, 10:27 PM
gkmccready
gkmccready's Avatar
400lbs difference between the two. I hope some of that is driver and fuel. :-)
Old 10-03-2006, 11:11 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Surely a C6 Z51 can't weigh 3470 without a driver and/or nearly full tank of fuel.
Old 10-03-2006, 11:44 PM
M_Minnick
M_Minnick's Avatar
Obviously the weights I posted are with driver. Also a little less than a half tank of fuel.
Mike
Old 10-04-2006, 05:50 AM
ghoffman
ghoffman's Avatar
Ok,apples to apples, driver and 1/2 tank of gas
To '07 C6 Z51 Scale/Alignment results
Quick Reply: '07 C6 Z51 Scale/Alignment results
