Cold tire PSI recomendations for V710s (17x11 w/ 315s)?
Old 06-14-2007, 10:31 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Cold tire PSI recomendations for V710s (17x11 w/ 315s)?
Running VIR this weekend w/ V710s for the first time... before this I rean Hoosier RS304s.
What should my cold pressures be? I put them all at 30 for now.
Old 06-14-2007, 11:21 AM
Z06cool
Z06cool's Avatar
Will be at VIR also. Hope to meet you. I start the day at 30F/28R and keep an eye on it rest of the day letting air out as necessary. Just read in another post some folks run it a lot lower though.
Old 06-14-2007, 11:27 AM
Cobra4B
Cobra4B's Avatar
I'll be trailering in an older silver Suburban and a 24-ft enclosed trailer w/ C5 emblems on it (borrowing the rig ).
Will be with my father in a blue Z-16 Z06 and Rich (DoingOK) w/ his Silver C6Z along w/ all the other jokers on here that decide to show.
Don't be a stranger!
~Brian
Old 06-14-2007, 11:28 AM
Cobra4B
Cobra4B's Avatar
Link?
Old 06-14-2007, 12:20 PM
Z06cool
Z06cool's Avatar
Originally Posted by Cobra4B
Link?
Bugs me that I can't fine the exact post I read just yesterday. Maybe another forum... Can't keep track sometimes. But a couple searches turned up these posts suggesting low pressures:
http://forums.corvetteforum.com/show...kumho+pressure
See you this weekend
Old 06-14-2007, 12:26 PM
MattW_VA
MattW_VA's Avatar
St. Jude Donor '07
I think it was Chris I that said he starts at low 20s in the front, high teens in the rear. I did the same last time out and had great success (watch that warmup lap though!)
Old 06-14-2007, 01:18 PM
wtknght1
wtknght1's Avatar
Yep, low 20s in front, mid to high teens in the back. That is with -3 F camber and -1.5 or so in back. The 710s have very stiff side walls so the pressures can be lower. Also, these tires have a HUGE performance window. Believe it or not, raising or lowering the pressure 5 psi really doesn't affect the handling of the car that much!!
Get a pyrometer and check your tire temps after a run (while the tires are still really hot), and adjust your pressures from there. One good test is worth 1000 opinions!
Old 06-14-2007, 01:21 PM
Cobra4B
Cobra4B's Avatar
^ thanks... Jody said 33-35psi hot... I'm going to start out at 28f and 26r and go from there.
Old 06-15-2007, 11:20 AM
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
I tend to start with 28 on all 4 corners. I have T-1 Sway bars and the car is setup fairly nuetral. You are likely going to have to bleed them off a few times depending on how hot it is outside and how hot the track gets.
Old 06-15-2007, 11:42 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
I do the same and get 35 front and 33 rear hot pressures.
Bill
To Cold tire PSI recomendations for V710s (17x11 w/ 315s)?
Quick Reply: Cold tire PSI recomendations for V710s (17x11 w/ 315s)?
