Autocrossing Rotors
Old 06-14-2007, 11:56 AM
ltborg
ltborg's Avatar
Default Autocrossing Rotors
well, my stock rotors finally got some small cracks in them so its time for new ones. i have hp+ pads going on with the switch. i am prepping the car for autocross but i do drive to events and would like to be able to attend track days/hpdes without having to put a whole new brake system on. looks like napa rotors are fine if you have ducts but i would like to take this opportunity to shave some weight. cant run titanium rotors (must have 100% ferrous material for the friction surface not to mention i dont want to dump $4k into rotors) so i guess id be running stock or two piece. any recommendations?
Old 06-14-2007, 01:53 PM
Aardwolf
Aardwolf's Avatar
The lighter the better, but can you afford them? The replacement two piece are to costly for my use.
Old 06-14-2007, 02:25 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
I've had heat-checking on my rotors (a.k.a. "spider-webbing") for the past couple of years autocrossing. I'm running PFC Z-rated pads, and have a set of HP+ pads waiting when these go away.
I understand about reducing rotational mass, but the rotors aren't that far away from the hub centerline, as far as inertia goes, and reduced mass equals reduced braking capacity.
HTH, and have a good one,
Mike
Old 06-14-2007, 02:45 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
For AutoX you should be fine on stock or NAPA rotors.
HP+ pads are very streetable ... little harder on rotors than stock Z06 pads.
I used them for HPDE as well with street tires. I'm not as hard on brakes as some (and have DRM ducts withhose and spindle mounts.)
I'm mounting CarboTechs 10's/8's for HPDE now with Nitto 555rII's (yes, I have to drive to the track ...)
Old 06-14-2007, 02:52 PM
KBRVETTE93
KBRVETTE93's Avatar
Remember to break in the pads with the old rotors.
Old 06-19-2007, 04:29 PM
ltborg
ltborg's Avatar
are there 2 piece stock sized rear rotors? seems like its either:
stock
stock sized cross drilled, slotted, etc. 1 piece
big brake kits with 2 piece rotors
Old 06-19-2007, 04:37 PM
rws.1
rws.1's Avatar
I use Raybestos PG + solid rotors from Rock Auto... $100 delivered for 4
Old 06-19-2007, 05:13 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
What class santioning body are you running in?
Old 06-19-2007, 07:26 PM
c4cruiser
c4cruiser's Avatar
I would go with AC Delco stock or the NAPA replacements and toss them once they begin to show cracking. The NAPA rotors aren't expensive and are widely available. The Hawk HP+ pads will work fine with stock-type rotors and will work great on the street once they get a little bit warm.
Ducting air to the rotors won't hurt, shouldn't cost a lot and they won't weigh much at all.
Old 06-19-2007, 10:57 PM
ltborg
ltborg's Avatar
SCCA SM2, possibly NCCC Class III but right now I'm sticking to SCCA until I can free up some more time.
Old 06-19-2007, 11:48 PM
Lancer033
Lancer033's Avatar
unless you're in the running for a national championship and are trying to shave off hundredths of a second, or have money to burn, stick with the NAPAs.
To Autocrossing Rotors
Quick Reply: Autocrossing Rotors
