Suggested psi range?
Old 06-21-2007, 06:50 PM
Jay86
1st Gear
Jay86's Avatar
Default Suggested psi range?
Hey, I was wondering what a good rule of thumb is for setting your tire pressure for autox events. Any suggested ranges?
thanks
Old 06-21-2007, 07:08 PM
Aardwolf
Aardwolf's Avatar
It varies a bunch depending on type of tire, outside temp., etc. I set mine cold and start at 32. Watch the wear line on the tire and adjust, also adjust for under/oversteer. The last time I was on the track I used 31.8 PSI.
Quick Reply: Suggested psi range?
