Tire comparison....for what it's worth...A6...NT-01...A3S05..R3S05
Old 06-22-2007, 05:26 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Tire comparison....for what it's worth...A6...NT-01...A3S05..R3S05
I ran all sorts of tires at Grattan last weekend
Saturday
I ran Nitto NT-01 275 17 ft & 315 18 Rear for two sessions these tire were purchased new the beginning of last session I'd say they have about 20 Autocross runs and about 10 track day each with 2-5 20 minute sessions so let's say 40-50 heat cycles.
Best time 1:27.6
Than the last two sessions I ran Hoosier A6 up front 275 17 & Hoosier A3S05 295 18's out back the A6s have about 15-20 heat cycles & the 05s have about 19-24 heat cycles.
Best time 1:27.494 ( I had metal showing through the one rear tire about an 1 inch ban all around))
On Sunday
I ran the same A6s up front with 2 more heat cycles & a set of R3S05s in the rear 295/18s ( bought them as scrubs so I have no idea how many heat cycles)
Turned a best of 1:27.465
I ran two hot sessions on each combo.
My conclusion old Nitto's are just as good as old Hoosiers
For a reference point last year when the Hoosiers were new I ran a 1:27.2xx from a dead stop at the beginning of the straight with the start finish in the same spot.
I'd say new hoosiers sould be good for at least a second.
Old 06-22-2007, 06:33 PM
TommyBoy72
TommyBoy72's Avatar
Good info. What is the longevity of the NT-01? Say compared to RA-1s for comparison if you have that data. I'm leaning towards one or the other for DE's.
Old 06-22-2007, 07:15 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
I would guess the NT01 will last longer because the compounds are very similar if not identical and the NT01 has much larger tread blocks that will help eliminate some of the wear the Toyo's get with their rather smallish tread blocks.
Just a wild *** guess
Old 06-22-2007, 09:58 PM
L98Terror
L98Terror's Avatar
My NT-01 still have about 50% life left and I have a ton of track time on them I believe they really don't drop off nearly as much as the other tires.
I don't have new NT-01 data vs New Hoosier but I would believe the Hoosier are faster new, but I have run the NT-01s competitively against people running Hoosiers and Kuhmos.
Old 06-22-2007, 10:10 PM
varkwso
varkwso's Avatar
Originally Posted by L98Terror
My NT-01 still have about 50 life left and I have a ton of track time on them I believe they really don't drop off nearly as much as the other tires.
I think new Kumhos and Hoosiers are faster than NT01s but I think their performance drops off quicker then the NT01s. They are cheaper than the Kumho and Hoosiers...
Old 06-24-2007, 08:06 PM
greendot
greendot's Avatar
apples and oranges comparing you to somebody else. I KNOW you !
Old 06-24-2007, 08:10 PM
L98Terror
L98Terror's Avatar
Did you go to the NCCC Convention? How'd you do? I was planning on going but forgot To wrapped up in NASA events I guess
Old 06-24-2007, 08:19 PM
greendot
greendot's Avatar
FORGOT?
Yes, we did it. Mary and I won LIM and IM in both high and low speeds and group 1 FTD's in the High speed. Nice young guy, local SCCA driver named Micah (?) got me for low speed group FTD.
Old 06-24-2007, 08:33 PM
L98Terror
L98Terror's Avatar
FORGOT?
Congrats.
Yeah, when I just saw the pictures posted I was like DAMN! & to think I could have driven down run the Hi speed and come home
Maybe it was because I was too busy teaching my ringer to take Mary down
Old 06-24-2007, 08:55 PM
greendot
greendot's Avatar
too kool
Old 06-25-2007, 01:56 AM
gregkono
gregkono's Avatar
Default Where to/how much/ purchase Nittos?
Where did you purchase the Nittos from? What sizes for your Z? I've burned thru Sport Cups and Hoosiers and am looking for a "longer" wear DE tire. Thanks, Greg in SW Mi. (Grattan 1:27.8 Gingerman 1:31.5 Mid Ohio 1:49.4 Road America 2:35.6)
Old 06-25-2007, 01:07 PM
L98Terror
L98Terror's Avatar
http://forums.corvetteforum.com/show....php?t=1738717
Discount Tire $225 each for 315s shipped to your house...
I paid way more than that, maybe they lowered thier prices. I got mine though Discount Tire as well. I'm running 275/40 17 up front and 315/30 18s in the rear.
Great times, anything done to your car? Mid-Ohio times look slow I'm thinking I'll need a 136 ish there.
Old 06-25-2007, 01:13 PM
varkwso
varkwso's Avatar
315/35-17s are the size - just ordered two more. One reason I switched to 17s...
Old 06-25-2007, 01:15 PM
L98Terror
L98Terror's Avatar
Oh! OK I think I paid over $300 for the 315/18s...makes sense now
Old 06-25-2007, 05:32 PM
varkwso
varkwso's Avatar
$312 is what they charge today for 315/18s...
To Tire comparison....for what it's worth...A6...NT-01...A3S05..R3S05
Quick Reply: Tire comparison....for what it's worth...A6...NT-01...A3S05..R3S05
