WIlwood SL-6 bleeder size
Old 07-04-2007, 01:39 PM
5.0e303
5.0e303's Avatar
Default WIlwood SL-6 bleeder size
Hey guys,
I have a couple broken bleeder screws that id like to replace on my SL-6 woods. Are these bleeders specifc to wilwoods or can i just get some speedys at the local parts store? IF so, do you know the size?
The previous owner got carried away i guess ;o)
thanks!
Old 07-04-2007, 02:21 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,911 Likes on 5,325 Posts
You need to get special bleeders from Wilwood. Sadly they are not the same size as the bleeders on the Wilwood calipers used by the circle track racers. They come in a 4 pack. My local circle track parts supplier was able to order them from his catalog.
Bill
Old 07-04-2007, 02:56 PM
Aardwolf
Aardwolf's Avatar
Speedbleeder lists them, here is a link:
http://speedbleeder.zoovy.com/c=nZ9Z...lwood%20Brakes
Old 07-04-2007, 03:27 PM
Bill Dearborn
As I said the bleeders for some of the other Wilwood calipers would not fit the SL6 calipers. I had them in my hand and was able to compare the two. I am not sure which bleeder is referred to in this link but am suspicious since it says "all".
Bill
Old 07-04-2007, 03:29 PM
5.0e303
5.0e303's Avatar
great thanks for the help guys!
Old 07-05-2007, 02:49 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm running SL6 calipers with speed bleeders. They are nothing special, something like 1/4-28 thread, I don't recall exactly. I picked up them up off the shelf at Napa, very standard size.
They seat into the larger brass fittings, I presume to protect the aluminum caliper.
Old 07-06-2007, 07:59 AM
Lancer033
Lancer033's Avatar
if you have some OEM calipers around, you can take the insert out and use the OEM sized bleeders
To WIlwood SL-6 bleeder size
Quick Reply: WIlwood SL-6 bleeder size
