F/S X-World Challenge C5
Old 07-06-2007, 05:28 AM
sgsvette
sgsvette's Avatar
Default F/S X-World Challenge C5
Last year run in World Challenge was 2003, been garaged since then with a few local races.
Engine package:
Dry Sump stroker motor making 590 HP.
Headers with X pipe and down exhaust
Light weight aluminum radiator with oil cooler
ASA wiring harness
FAST intake manifold
FAST 90 mm mechanical throttle body
Suspension:
Moton triple adjustable coil over shocks
GM Performance front & rear sway bars
3R Racing rear toe links
GM Racing wheel hubs
Brakes:
Brembo 4 piston Calipers with 14” floating rotors on front
GM 2 piston Calipers with 13” rotors in rear
Cobalt Racing pads all around
Driver adjustable brake bias valve
ACP 5” carbon fiber brake ducts on front
GM rear brake ducts
Fuel System:
25 gallon fuel cell
Dry Brake fueling system
Adjustable fuel pressure regulator
Fuel Pressure gauge
Running Gear:
Tilton Triple disc racing clutch with ring gear
GM Performance close ratio 6 speed transmission
BPP short shifter
4:10 ratio special treated differential
Transmission and differential coolers
Upgraded GM torque tube
3 sets of custom made 18” aluminum wheels
Body Work:
World Challenge Carbon Fiber front facia
C5R racing headlights (non pop-up)
Carbon Fiber under tray with tunnels & 4” extension
Carbon Fiber World Challenge louvered hood
Carbon Fiber light weight doors
Carbon Fiber light weight 1” flared rear fenders
Carbon Fiber light weight rear deck lid
Lexan front & rear windshields
72” World Challenge adjustable wing
Removable steering wheel
Momo Racing seat
6 point racing harness
Radio wiring with PTT switch and antenna
Analog gauges
Custom built roll cage
Transponder
Driver Cool Suit set up with fresh air supply
Fire Suppression system
Light weight defroster
See pictures on link:
http://forums.corvetteforum.com/phot...0&ppuser=27721
$65K O.B.O.
Old 07-06-2007, 07:43 AM
mikahb
Vetteless
Support Corvetteforum!
mikahb's Avatar
St. Jude Donor '09
I'm sure I need this car, just a couple years too early for me yet. Good luck with the sale!
Old 07-06-2007, 09:02 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Wow... screw a C6Z06.
Old 07-06-2007, 09:16 AM
Oyishdog
Oyishdog's Avatar
sounds like an awesome deal
To F/S X-World Challenge C5
Quick Reply: F/S X-World Challenge C5
