5-Point Harness Mounts....
Old 07-07-2007, 10:59 PM
BlackRocket
BlackRocket's Avatar
Default 5-Point Harness Mounts....
Where & what brand of 5-Point harnesses mounts are of good quality and not too expensive?
Thanks!
Old 07-07-2007, 11:00 PM
wallyman424
wallyman424's Avatar
6 point....
you'll thank yourself later.
Old 07-07-2007, 11:16 PM
jrz1
jrz1's Avatar
love my new teamtech harnesses.
Old 07-07-2007, 11:47 PM
ICaughtVetteFever
ICaughtVetteFever's Avatar
Hardbar and Pfadt Racing sell them
Old 07-08-2007, 12:50 AM
Joy of 6
Joy of 6's Avatar
Me 2. I have the 6 point in both seats
Old 07-08-2007, 06:41 AM
AU N EGL
AU N EGL's Avatar
6-point. 5-point's single sub belt may pinch the family jewls
Old 07-08-2007, 06:55 AM
jlucas
jlucas's Avatar
Schroth Hybrid II's are the most comfortable belts out there, especially when it comes to the family jewels.
Old 07-08-2007, 12:39 PM
BlackRocket
Where do you get the Schroth's and what mounts do you use???
Old 07-08-2007, 02:20 PM
earthman01
earthman01's Avatar
In my C5Z I used the Brey-Krause harness bar and Simpson belts. The shoulder belts loop around the bar and the lap and anti-subs go the anchor bolts behind the seat. There is a cross-member under the floor boards to anchor to, the same piece that the seat is bolted to in the rear.
Watch the placement of the bolts so that the seat clears when moved back. Your shoulder belts should have a sternum strap and buckle unless you have pass-throughs in your seat back.
To 5-Point Harness Mounts....
Quick Reply: 5-Point Harness Mounts....
