Too Tall Bob's newest ride!
OK, OK.... I know it's not completely Corvette related (yes, there is a Corvette in this video) but I wanted to show off my newest track toy.
Don't worry, my Z06 is still a blast to drive and is being readied for its' next event later this month, but for very little money, you can run VERY fast in this little sucker!
http://www.youtube.com/watch?v=6LqzafQMHGk
(Watch for my friend in the yellow Z06!)
Here is a pic of the car after being painted last week:
http://i14.photobucket.com/albums/a3...Picture059.jpg
http://i14.photobucket.com/albums/a3...Picture064.jpg
And, for those of you who just have to see videos of Corvettes and just can't stand the thought of something like that Roadster, here are a whole bunch of my videos of track events in the Corvette:
http://www.youtube.com/profile?user=tootallbob
That roadster appears to be an amazing little vehicle. What type of engine, driveline, HP, etc. Also cost if you don't mind us asking - Inquiring minds want to know facts please
Shame on you Bob for picking on other drivers like that.
What I want to know is if you make those hand gestures at me when you come up behind me?
It looked like a fine day at MMP!
Fastest regards,
Oli
Fastest regards,
Oli
Bob, that is so cool
It has changed since I climbed into it. What have you done besides the paint, extended the chasis and raised the roll cage?
Will you be running the series with Barry & Jordan?
I want to see that roadster in person, too bad it won't take a passenger
Janet
Janet
It uses an air-cooled 1,250cc Yamaha 4 cyl. engine out of the old FJ1300 motorcycles with just a couple of small modifications to adapt to these cars. The 130 HP engines are sealed and cannot be opened up except by authorized rebuilders, then they are re-sealed again for equality. They use a drive-shaft which powers a shortened rear end out of a Toyota Celica, and there are disc brakes all around.
The cars are built to be a "Spec Series" racer, and basically you are allowed to change the alignment, the rear end ratios, the air pressures, put in gas and go race 'em. Even the tires are spec tires made by Hoosier.
The Thunder Roadsters come in two flavors: an open-wheeled version which is the most popular and is used extensively on oval tracks, although they are used on road courses as well. This model that I have, has a "GP" body on it for roadracing, although the chassis underneath is identical. My car on the scales weighed in at about 1,160 lbs. wet without a driver.
They cost about $15,000 each and there are a couple of options such as fire suppression systems, a couple of engine upgrades for reliability, etc.
I believe that the Z06 was relatively stock and was running on GY F1's. He told me afterwards that he was pushing the car a little harder because he saw me flying up behind him. This car handles the turns so well that the Vette was no match for it except on the straights.
If you get really sideways and you save it, I give you a "Thumbs-up!!"
Actually, that guy in the silver Turbo Porsche had held me up earlier in the day and wasn't using his mirrors at all and was a bit of a "Road-hog". He obviously knew that I was back there, yet he lets the yellow Vette pass and not me. I always give somebody a quick "wave" of thanks when they point me by, but he was not very cordial that day. Doesn't it always seem as though the drivers with slower, high-horsepower cars are typically the ones who are less likely to let you pass simply because they can go so fast down the straights?
Did you notice that I was giving a "Thumbs-up" to the corner-workers after the passes? They were all hanging out of their corner stations waving me on as I was catching and passing other cars all day long. They really liked to see that car running!
Janet
Janet
Yes, the cage is modified, but the chassis remained the same.
I am right now, as we speak, trying to get sanctioning-body approval (INEX) to be able to run my car against the other spec roadsters. Initially, they did not approve any modifications to the chassis, but since the car was completed I have sent them photos and an explanation of what I modified and they are considering approving the car. I didn't do any "speed-enhancing" modifications, so I'm hoping that they'll allow the car to run.
Former Vendor
Very cool!!! I love bike motors and trannies. Huge power-small cubic inch-5 or 6 speed.
We have done some chassis dyno work on a spec car. 3 percent gain in under an hour
Have fun and be carefull with the tranny, they are pretty easy to get carried away with.
Randy
Randy
Really cool ride, looks like a real killer on the twisty tracks, but it was interesting watching the P car and C5 just vanish down that long (4000+ ft.?) front stretch. Then watching you fly the corners without hardly touching the brakes!
One curious question: the sound on the video when you were *off* the gas sounded really bad. What was that? Exhaust? Back-driving the gears in the tranny? It obviously was OK mechanically, but it sure sounded nasty.
That car sure looks like a blast to drive! Wonder how it would do on an autox?
Have a good one,
Mike
Have a good one,
Mike
Have a good one,
Mike
Have a good one,
Mike
Plus, you can go into corners so much deeper before jumping on the brakes, so alot of time was made up there as well.
The mic for the camera was mounted right above the rear diff, so I assume that most of that noise that you heard is from the rear end. At slow speeds, there is a signicant amount of gear whine, but because the exhaust is so loud, it's hard to hear anything else in the cockpit once up to speed. That car is REALLY loud and I had to wear earplugs!
As far as AX, you can put some really low gears in the rear end (mine was a 2:93) so I'm sure it would scoot along pretty good!
No....Not allowed to go and play with the Radicals yet. Gotta go play with about 100 Porsches this weekend first.
And, yes..... A Hans is on order at your request.
