Getting VB&P bushings installed next week... what should I expect? New allignment?
CI 3-5-6-7-8 Veteran
My front lowers are shot, so I'm taking the full poly plunge. I'm having them installed as I'm too busy to do it myself right now and really don't feel like futzing with it.
I have VB&P polys in my sway bars now and find that I have to re-lube them annually. I knwo teh VB&Ps will eventually squeek some, but I'm making my car a track car over the next few years so that's a non-issue.
I'm assuming overall handling will be improved and I won't have to worry about the front lower bushing squeezing out ever again.
My current allignment is as follows (street/track):
Front
-1.3 degrees camber
+6.x caster (I think)
0 toe
Rear
-0.9 degrees camber
1/16th per side toe-in
I know you don't need to run as much static camber w/ polys, but I'm guessing this only applys to race allignments which are far more aggressive.
I'm thinking of going to 1.5 camber up front and 1.2 rear when I get it re-alligned if possible. I still drive the car on the street a bunch.
~Brian
Front
-1.3 degrees camber
0 toe
Rear
-0.9 degrees camber
~Brian
Leave it as it is for now...until you get a chance to get on a track, take some tire temps and do some testing.
Always try to make one change at time. You've made that change - bushings. Now, go the track and see what the results are.
Take a set of toe plates to the track, and make a change (camber, etc) or two to one side of the car...use the toe plates to put your toe back where it was before. Note the changes.
Keep making tweaks like that until your tire temps, feel for the car, etc, etc is where you want it.
I'd rather set it and forget about it. I generally get the car re-alligned annually do to the control arm shifting throwing things out of whack.
You can expect lots of noise (sorry, couldn't resist). Why don't you try the recommendation of using some teflon wrapped around the mounting points before you install the bushings....love to hear if it works.
Fact is that it's a weekend toy now... I don't drive it to work since getting my truck. A quiet automatic is a nice thing for daily commuting duties.
If she squeeks on my weekend cruises then so be it... I'll have the windows down and the cam thumping.
I'll print out your post and show it to Greg who's putting them in for me. Can you elaborate on where to put the tape?
Toe plate kit (with 2 measuring tapes) is about $1 thru Longacre...get it. You won't regret it, cause you will need them at the track eventually.
Set it and forget it once you see what the car is doing first. One change at a time.
Location: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
I'm about to do mine too...did you buy the bushings right from VB&P? On their website I only saw a kit for the whole car for $299.....I don't want to change the rears....only the fronts. Did you buy just the fronts???
Have you considered drilling a hole and adding a zerk? Then they can be lubed anytime very easily.
What makes you think I live at home? This September I'll have owned my house for 3 years. Well technically the bank owns it, I just pay them to stay here
Bushings
I just bought a front set from VB & P. They will split a full set.
Re: squeek, squeek . I just put on a louder exhaust system.
Don't forget to mention the forum for a discount.
Ordered my front bushings this morning..shipping out today...
Like in this thread?
http://forums.corvetteforum.com/show...ht=zerk+grease
Here is some more talk of zerks to:
