who makes inexpensive 3 piece track wheels?
Old 07-25-2007, 08:26 PM
427Z
427Z's Avatar
Default who makes inexpensive 3 piece track wheels?
other than ccw as apparently they wont fit over C6Z brakes
Old 07-25-2007, 08:34 PM
PA Z06
PA Z06's Avatar
Call John at CCW, im pretty sure he can custom make you a set.
Old 07-25-2007, 08:48 PM
427Z
427Z's Avatar
iv been told (though not by john himself), that the classics cant be made to clear the z brakes. maybe i should call...
Old 07-25-2007, 10:08 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Gary Hoffman has CCW's on his C6Z, I don't think they are classics though.
Old 07-25-2007, 10:10 PM
427Z
427Z's Avatar
they are corsairs
Old 07-25-2007, 11:07 PM
63Corvette
63Corvette's Avatar
I run Kinesis K27 3 piece wheels to cover my Stoptech 14" brakes.
Old 07-26-2007, 12:03 AM
0Vector Vette
Former Vendor
Vector Vette's Avatar
CCW Corsairs will fit over any brakes and they do make them for the Z06. They are not all that cheap though at aprox. $2800 for a set.
Old 07-26-2007, 07:04 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Corsairs will fit.
Also check with John because my 17in ccw classics fit over my Wilwood big brake kit with a very small spacer on the rear.
Old 07-26-2007, 07:18 AM
AU N EGL
AU N EGL's Avatar
I Forge makes three piece wheels too.
Kinesis was sold to another company
BBS went into Bankrupcy and was bought out by a Belgian company along with the American Importer of BBS wheels in Brasilton GA
Old 07-26-2007, 09:46 AM
cendres
cendres's Avatar
Have you looked at Forgeline?
Old 07-26-2007, 09:54 AM
ccdan
ccdan's Avatar
The classics will not clear C6Z06 brakes due to the pad of the center not being long enough (in its original state) to hit the correct backspacing numbers. With the corsairs the backspacing requirement can be met easily and has less deflection making it a better piece for the job. You can call and talk to John; he'll explain all the mumbo jumbo specs to you. :-)
There has been a new 3pc center in development that hasn't been tested yet and not sure if it will actually be a production piece but would clear the brakes. It's pad is longer and with a design caliper clearance is even greatened more. The only problem I foresee in the design is that "the design changed"; a lot of ppl like the classic design so with the new one you ether love it or hate it. Here's a preview:
Old 07-26-2007, 10:03 AM
XPC5R
XPC5R's Avatar
Not sure about inexpensive (none of these are), but Forgeline does. See what LGM runs on their race and street cars.
Old 07-26-2007, 10:18 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Another set of stock wheels, especially used, would be probably the least expensive option.
I do indeed have the Corsairs (2 sets) and the caliper clearance is huge, I could run a Wilwood STR caliper if I wanted to. I get alot of calls on this subject and if you ever think you might change brakes in the future, rotor-to-wheel spoke clearance is the biggest issue to maximize your options. The Corsairs on my car have 4 inches of clearance for the calipers!
Old 07-26-2007, 10:35 AM
AU N EGL
AU N EGL's Avatar
Dan
Those new 3-piece wheels look great. Set a set to me and I will test them out for you guys.
Old 07-26-2007, 06:41 PM
427Z
427Z's Avatar
i have had 1 set of the corsairs and 3 sets of the classics. corsairs arent bad but the classics are a good bit lighter. the outer rims on the classics seem to weigh just ounces.
the prototype looks good to me. lets see if john builds it. i would be interested
i was hoping to get names for additional manufacturers. i came across a website a couple of years ago that had 3 piece track wheels for about 1900 a set. they even had 4 or 5 different centers to choose from. they were in canada and the name was something like circle track but i cant locate them now
Old 07-26-2007, 07:41 PM
MUKAK
MUKAK's Avatar
i like the new classics i hope John makes them
Old 07-26-2007, 07:59 PM
427Z
427Z's Avatar
call me crazy but i like the new design better
To who makes inexpensive 3 piece track wheels?
Old 07-26-2007, 08:28 PM
ghoffman
ghoffman's Avatar
I do too, they are very nice.
Old 07-26-2007, 11:19 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Originally Posted by ccdan
17 x 8.5's & 10's in custom backspacings for C3 w/1/2" x 3" lugs, black powder coated or black anodized centers??
Old 07-27-2007, 07:18 AM
Bluewasp
Bluewasp's Avatar
NoVa Events Coordinator
St. Jude Donor '14
I have CCW classics over a 6 piston brake setup... Talk to john he will make something that fits..
Quick Reply: who makes inexpensive 3 piece track wheels?
