Diagnose this noise?
St. Jude Donor '07
Hearing a grinding/scuffing noise from the right front on low speed(parking lot manueveruing) left turns. Wheel bearing maybe?
Check for rubbing issues first.
CI 3-5-6-7-8 Veteran
Do you have cooling ducts rubbing? A wheel bearing will normally start to roar at speed, then when you slalom the car the noise will go away as the bearing is loaded.
