C6 rear rotor weight info
Old 08-13-2007, 07:23 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Default C6 rear rotor weight info
Interesting, I weighed the 13 inch C6 rotor as compared to the 13.3 inch C6ZO6 rotor. The 13 inch C6 rotor is 20.0 pounds, but the larger diameter 13.3 inch C6z rotor weighs 19.2 pounds. In addition, the C6 rotor is directional and all left side rottation, but the C6ZO6 larger but lighter rotor is a "Kangaroo paw" type rotor.
Quick Reply: C6 rear rotor weight info
