Portland International Raceway getting repaved
Old 09-08-2007, 08:39 PM
micro
micro's Avatar
Default Portland International Raceway getting repaved
PIR Repave Is On!
The long-anticipated repaving of PIR has been given the green flag by the City of Portland. A contractor has been secured and the money has been approved both by the Parks Department and by the Portland City Council.
"This is the culmination of a lot of hard work by a lot of people, but the results will be well worth the effort," said PIR manager Mark Wigginton. "The old surface is pretty well worn out."
The repaving will eliminate many bumpy sections of the track, and offer the opportunity to realign and widen a few key areas around the course.
"We're moving Turn 6 about 50 feet to the west, shortening the 5-6 transition, but lengthening the 7-8 area, and we're widening Turn 7 in the process," Wigginton said. "That will create a new passing area in the braking zone before Turn 7."
The repave begins on September 17, and will be completed sometime in October. The first cars on the new pavement will be the Holiday Lights visitors this fall, and racing is scheduled to resume in the Spring. This delay is absolutely necessary to allow the new surface to cure and solidify before the stresses of racing are reintroduced.
The new racing surface is expected to last 15 to 20 years before repaving again becomes an issue.
http://www.friendsofpir.com/fopir/index.php
Old 09-08-2007, 09:08 PM
kentz06
Support Corvetteforum!
kentz06's Avatar
This is great news! Both the Miata and the Z will be very happy!!!
Dean
Old 09-18-2007, 11:41 PM
Zee Freak
Zee Freak's Avatar
St. Jude Donor '03-'05-'06
Here is a PDF of the track redo. Someone posted it on the PDXracer list.
http://www.lichty.org/MiscImages/PIR_Repave_Plan.pdf
Old 09-23-2007, 12:14 PM
c4cruiser
c4cruiser's Avatar
The new Turn 7 looks great. And that broken up area on the right side of Turn 8 will be gone! The pdf plan also shows revamping 4A to 30 feet wide.
To Portland International Raceway getting repaved
Quick Reply: Portland International Raceway getting repaved
