Does Trailering with the Parking Brake on Wear the P-Brake?
I've noticed that my parking brake has become useless and was wondering if trailering with the brake on has added to the wearing out of the p-brake pads. Anyone else have this problem?
What's an easy way to adjust the p-brake? I thought you just pull up on the handle a couple of times and it self adjusts but that doesn't seem to work.
Any advice?
Any advice?
I am not sure why you would trailer with the parking brake on. However driving with it engaged has the brakes on at all times and would wear them and generate a lot of heat. I would take apart the parking brake and check it out.
Mat
Mat
I would always set the parking brake while trailering. The cycling you refer to is the procedure if there is slack in the brake cable. I think you will have to adjust the "star adjuster" on the inside to get more bite.
HTH
HTH
If it is adjusted properly and set when on a trailer it can't wear because it can't move. Pad material is like a thin potato chip and may be gone,
Former Vendor
Parking brake on is fine, just never allow the car to be trailered in gear. It will rock on that gearset with no oil. Remember, when the car is moving on the track/road, the gears will have oil all over them, when its on a trailer, it will rock back and fourth with out getting oil on it.
I'm not exactly sure why yours are worn out, but trailering it with the brake on isn't the problem.
One possible wear problem though could be that the parking brake shoes may actually be slightly touching the inner ring of the rear rotor(s) causing them to wear...and for you to lose a slight amount of power.
Joe's guys at Phoenix have dyno'd cars that didn't come up to specs and sometimes that was the reason. They have seen where not only was it just barely touching, but in some cases severe. Make sure that the rear tires rotate freely...and not dragging on those shoes.
I'm kind of perplexed by this. The P-Brake worked fine up until about three events ago. Now it doesn't seem to work. Since I park on the tilted trailer it's very important that when I take the last tie-down straps off the car has to hold! I've started to put it in gear before removing the tie-downs just to be sure.
I guess I'm going to have to tear into it this weekend before my trip to Topeka next week. The car's working so well I hate to touch it now.
Try simply setting and releasing the P-brake 2 or 3 times in a row. Most times after I've been driving and first set the P-brake, it doesn't engage well enough to keep the car from rolling. But if I release it and reset it, then it engages and the car stays put. Little bit of self-adjustment built in I suppose...
Fred
Fred
