'02 Z06 shock upgrade question
Old 09-20-2007, 09:41 PM
danbo56
danbo56's Avatar
Default '02 Z06 shock upgrade question
fellas...
it's time to swap out shocks on my 2002 Z06. I want to switch to '04's. I heard that Chey also changed the rear sway bushing's and control arm bushing too. Does anyone know the details on the '04 suspension changes? Part numbers? A good place to buy this stuff?
tanks.....
Old 09-20-2007, 09:53 PM
jbauch357
jbauch357's Avatar
Can't tell ya for sure on the sway bars and such...
... but consider Bilstein Sports while looking at shocks. They will be quite a bit cheaper than the '04Z shocks, and I beleive they can be rebuilt too. I threw them on my '02Z and am very happy with the results.
Old 09-21-2007, 09:40 AM
danbo56
danbo56's Avatar
Default ttt
thanks....
Old 09-21-2007, 10:18 AM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Default SOS for '04 Z shocks
Try Gene Culley at GM Parts House if you want '04 Z shocks.
Old 09-21-2007, 11:55 AM
Joy of 6
Joy of 6's Avatar
Originally Posted by MungoZ06
Try Gene Culley at GM Parts Direct if you want '04 Z shocks.
Or ask Gene about the C6 Z06 shocks which are near half the price of the 04's and pretty close to the same specs. I replaced my 02Z with these and am quite happy with them.
Old 09-21-2007, 06:08 PM
danbo56
danbo56's Avatar
Ok.... i did some more homework and found part of the answer:
  • Besides the new shocks, there are two other changes. Front, upper control arm bushings now use higher durometer rubber to reduce compliance. This increases front "camber stiffness" under high cornering loads, especially during hard cornering over chatter bumps. The increased camber stiffness makes the front end stick a little better so, to balance the car, a little rear end grip was added by increasing the compliance of the rear stabilizer bar mounts. This had the same effect as a slight reduction in bar diameter but was less costly than tooling-up a new rear bar.
Old 09-22-2007, 07:00 PM
sothpaw2
sothpaw2's Avatar
Does one have to replace all 4 or just the rears (ie is 02 front = 04 front?)
Old 09-22-2007, 07:41 PM
vms4evr
vms4evr's Avatar
All 4. Well worth it.
Old 09-22-2007, 09:11 PM
MungoZ06
MungoZ06's Avatar
Old 09-22-2007, 10:51 PM
danbo56
danbo56's Avatar
OK... all 4 shocks got it (part number 10339944 and 10339945) ... but what about the front upper control bushing and rear stabilizer bar mounts.
Can I just goto chevy and order those parts?
To '02 Z06 shock upgrade question
Quick Reply: '02 Z06 shock upgrade question
