Nordic Supercar C6 chassis.
For those who dont remember the car I start of whit a "reminder" image.
The image is a computer construction of what the car is going to look like.
http://www.hemipanter.se/A%20send%20bak-side.jpg
We have now finished the work with the chassis and suspenion systems. Theese images is before everything is painted. Engine is
mounted very fare back in the chassis, the front mounting plate is aft of the front wheels and the mounting ears could bee seen at the rear upper A-arm leg mount.
http://www.hemipanter.se/Corvette%20...system%201.jpg
http://www.hemipanter.se/Corvette%20...20uppright.jpg
http://www.hemipanter.se/Corvette%20...suspension.jpg
Here is all the weight numbers of the parts, sorry its in kilo:s, but kg*2,2 make pounds.
http://www.hemipanter.se/Vikter%201.jpg
Goran Malmberg
Goran Malmberg
wow, and in Norway
good to see that someone take on this task in Norway, where tracks are limited and we are gouverned by people who thinks gearheads are insane people and should be locked behind bars :-)
What are the rules in Nordic supercar ?
Could you start with a stripped down Z06 and still have a good base ?
what is weight and HP regulations, ie if i started with a stripped down Z06, and 600 Hp how much does the car gas to weigh ?
TIA
Rune
TIA
Rune
1. good to see that someone take on this task in Norway, where tracks are limited and we are gouverned by people who thinks gearheads are insane people and should be locked behind bars :-)
2. What are the rules in Nordic supercar ?
3. what is weight and HP regulations, ie if i started with a stripped down Z06, and 600 Hp how much does the car gas to weigh ?
TIA
Rune
TIA
Rune
2. You have all the rule here http://www.nordicsupercar.com/regelinfo.php
You could use a Z06 to fit in the rules, but refabricate a Z06 for the same underside designe is no easy task.
I designed this car from a clean sheet of paper to take advantage of an A-arm geometry that works together with quite good groundforce. The car is only 39" in height, 79" wide, Tw 64,5", Wb 95,6" which is short by many standards but our tracks is not to long and fast.
3.
You have everything in the rules supplied.
Regard
Goran Malmberg
Hey guys-
What happened to the supercarno website? If Alf ever wants to sell his Studebaker, I'm in!
Keith
I guess I should have waited a few minutes.
Keith
