How do you clean off old loc-tite when doing brake work?
Old 10-10-2007, 02:18 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default How do you clean off old loc-tite when doing brake work?
I haven't used it in a while becuase I find that the bolts are not loosening up at all. That said, all my bolts still have loc-tite on them. What's the best wayto clean them up to apply a fresh coat?
When changing a cracked rotor at the track what do you do? I guess you could cary a spare set or something that are cleaned up.
Old 10-10-2007, 02:27 PM
rbl
rbl's Avatar
Most people don't use it anymore because they are taken off so frequently. I stopped over a year ago ... no issues.
Heat is the easiest, wire brush is next.
Old 10-10-2007, 02:29 PM
Cobra4B
Cobra4B's Avatar
^ Good call.... just wanted to double check. I will use my vice and some heat to clean them up after this weekend at VIR.
Would it be ok to use a quick blast from a torch and a wire brush? Or is a lighter enough?
Old 10-10-2007, 02:32 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
I don't use it either but to answer your question, I use a tap in the holes and a die on the bolts with some WD-40. The big bolts that hold on the steel bracket to the upright are M14x2.0 thread size.
Old 10-10-2007, 02:56 PM
Cobra4B
Cobra4B's Avatar
^ Do you know what size the caliper slide pin bolts are?
Old 10-10-2007, 04:02 PM
trackboss
trackboss's Avatar
Thread chaser or a thread file.
Old 10-10-2007, 04:08 PM
Miaugi
Miaugi's Avatar
Wire brush.
Old 10-10-2007, 06:16 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Wire wheel on my bench grinder.
Old 10-10-2007, 07:06 PM
94ZR1#444
94ZR1#444's Avatar
Originally Posted by Miaugi
Wire brush.
The best way.....
Old 10-10-2007, 08:40 PM
trackboss
trackboss's Avatar
Depends what you mean by best, but if its simplicity just replace the bolts with new ones, and keep the used ones for spares. The tap would not be at the bottom of the list if I ranked the above suggestions simply because it cuts and can weaken the threads. I have used all the above methods with success however. My recommendation would be to throw a thread chasing kit in your toolbox. It can repair damaged threads as well as clean them and a good kit is only about $50. I use mine quite often. Good idea to always clean threads, if not replacing bolts, when they have sealer or locktite. Even new bolts sometimes don't have perfect threads. Anytime engine work is done, such as r/r cylinder heads one should always chase the threads in the motor and blow out the holes with compressed air.
-V
Old 10-10-2007, 10:57 PM
Cobra4B
Cobra4B's Avatar
^ Any link to this tool so I can see what you're talking about.
Old 10-11-2007, 07:28 PM
johninar
johninar's Avatar
That's me.
Old 10-11-2007, 11:24 PM
trackboss
trackboss's Avatar
http://www.matcotools.com/Catalog/to...select=&page=2
That is what I have, but you can get the craftsman one for about half the price and its nearly identical.
-V
Old 10-12-2007, 12:13 AM
Hardcorvette
Hardcorvette's Avatar
St. Jude Donor '06-'07-'08-'09-'10
Ditto...makes for quick work.
Old 10-12-2007, 08:57 AM
Lancer033
Lancer033's Avatar
That's what I do now. Used a wire brush until I had to get a tap/die set a while back, but it's a lot more work.
Old 10-12-2007, 09:15 AM
ghoffman
ghoffman's Avatar
It is an M8x1.25. How do you wire brush fans clean the internal threads? If you don't do that, it is only doing 1/2 the job.
Old 10-12-2007, 11:16 AM
rws.1
rws.1's Avatar
I have used a wire brush and sometimes a utility knife for really stubborn thread locker...
Hdd to slap myself that I never thought of a thread chaser...
Old 10-14-2007, 03:27 AM
Last C5
Last C5's Avatar
And my vise grips.
To How do you clean off old loc-tite when doing brake work?
Quick Reply: How do you clean off old loc-tite when doing brake work?
