What tools are really for . . .
Old 11-07-2007, 11:01 AM
AU N EGL
AU N EGL's Avatar
Default What tools are really for . . .
A friend sent this to me. a little fall humor
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar callouses from fingers in about the time it takes you to say, "Yeouw s--t...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. The most often used tool by all women.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or ½ socket you've been searching for, over the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. The accessory socket within the base, has been permanently rendered useless, unless requiring a source of 117vac power to shock the mechanic senseless.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids, opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal- burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 30 years ago by someone at Ford, and instantly rounds off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. Women primarily use it to make gaping holes in walls when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. It is also useful for removing large chunks of human flesh from the user's hands.
DAMNIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMNIT" at the top of your lungs. It is also, most often, the next tool that you will need but can't find.
Old 11-07-2007, 11:52 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,391 Likes on 744 Posts
That is one awesome list!! However, the trouble light description missed one important use: to apply heat in a random pattern intended to maximize melting of wire insulation or plastic retainers.
I'm sure I've missed others, though.
Have a good one,
Mike
Old 11-07-2007, 12:00 PM
joemoia
joemoia's Avatar
Old 11-07-2007, 12:18 PM
trumper Z06
trumper Z06's Avatar
Thanks, Tom !!!
Old 11-07-2007, 12:41 PM
AU N EGL
AU N EGL's Avatar
Old 11-07-2007, 01:14 PM
robvuk
robvuk's Avatar
Thanks Tom! I needed that.
Old 11-07-2007, 01:37 PM
Z Fast
Z Fast's Avatar
Location: Bend, Oregon Black / Ebony 2LZ 2006 Z06 C6Z06 owner since 2/7/2006
Very funny
Sad , but so true in many ways Been there, done that in some cases. It definitely explains why I told my wife not to worry about hanging that new shelf on the wall. I'll just do it. I just don't want to have more holes than neccessary.
Old 11-07-2007, 01:38 PM
outnumbered
Support Corvetteforum!
outnumbered's Avatar
We could all use some of that. That last tool is my favorite. I have too many of those.
Old 11-07-2007, 02:18 PM
robvuk
robvuk's Avatar
You might have too many but I've used it too many times.
Old 11-07-2007, 03:12 PM
Last C5
Last C5's Avatar
Excellent!!! And I think I have every one of those. I also have a propane flame thrower, but my wife has forbidden me to use it anymore. But really, who knew that the electric company would coat thier poles with a flammable material. :o
Old 11-07-2007, 03:26 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
now i am positive ...someone has been watching me work in my shop!!!!
Johnny
Old 11-07-2007, 04:25 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I have a toolbox full of damnits
To What tools are really for . . .
Quick Reply: What tools are really for . . .
