Good road racing front tire width?
Old 11-07-2007, 04:37 PM
gkull
gkull's Avatar
Received 1,331 Likes on 1,059 Posts
Default Good road racing front tire width?
I have been running 11X25X15 Goodyear road racing slicks on the front and 12X27X15 rears. The problem is at as my power jumped up substantualy and I exceeded my brakes.
So I have upgraded the brakes to a Wilwood Thermlock piston on 13 inch two piece with air ducting and 600 degree fluid.
My past tire combo was very neutral. I could go from understeer to oversteer with just a change of the throttle
I have been looking at some 9.5 inch aluminum front wheels in 17's and 18's. I could not find 10 inch. maybe somebody here knows of a manufacturer?
I'm looking at 275/40 and 295/35.............. What are you guys using?
Old 11-07-2007, 04:42 PM
69autoXr
69autoXr's Avatar
Look at CCW's, they can make you just about any width in 17 and 18. Personally I plan to eventually get 17's with 315's all around or 315 front and 335 rear.
Old 11-07-2007, 04:44 PM
Mojave
Mojave's Avatar
I ran 335's front and rear on my C4.
Old 11-07-2007, 04:57 PM
Carl Johansson
Carl Johansson's Avatar
Hey George,
we run 275 40's up front on Scotts rig!
carl johansson
Old 11-07-2007, 05:03 PM
gkull
gkull's Avatar
The tire rack listing for the A6 tires 275 was 10.3 and the 295 was 10.8 inches of tread width so they are both very close to my existing 11 inch.
The 315's require a 11 inch wheel and I am not sure at what width are you not getting enough pounds per square inch to make them work right.
Old 11-07-2007, 05:30 PM
69autoXr
69autoXr's Avatar
I wasn't telling you to get 315's, I said to check out CCW as they'll have the wheel sizes you're looking for.
I am going to use 315 fronts, but I have flares to fit 11" wheels.
Old 11-07-2007, 07:15 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
305 & 335 18's
Old 11-08-2007, 12:36 AM
gkull
gkull's Avatar
Originally Posted by Carl Johansson
Hey George,
carl johansson
I just saw your post. Has Scott felt the need for wider 295s?
I really like the Goodyear slicks. The only problem with them is the wheels are only for the stock brakes. For @ $200 per tire they are really pretty nice. even when I got into a turn way to fast, the push condition with your foot off the gas would cause the car to scrub off enough speed to rehook up and go.
To Good road racing front tire width?
Quick Reply: Good road racing front tire width?
