155 mph @ VIR back straight
Old 11-20-2007, 07:39 PM
USA1C5
Support Corvetteforum!
USA1C5's Avatar
Default 155 mph @ VIR back straight
Just curious of what kind of speeds are being obtained on VIR back straight. My first HPDE there with NCM back in July I couldn't make 150 mph. I could get close at 149 mph. This past Monday Nov. 19 at a HPDE by TrackDaze I made 155 mph. I don't know what the difference in speeds is due to unless it's temperature related. It was a bit cooler Nov. 19 but not a big difference, maybe around 15 to 20 degrees. Could the temperature make that big a difference?
Old 11-20-2007, 07:47 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
temp helps but so does being familar with the track.
Old 11-20-2007, 07:51 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Proper entry and Exit from the preceeding turns is the key to speed on the straights. I think that your familiarity with the track has a lot to do with your increased speed. Cooler ambient air allows more HP which helps too.
Old 11-20-2007, 07:56 PM
freefall
freefall's Avatar
Oak tree will make your speed. The stockish c5z guys are about 150.
Old 11-20-2007, 07:58 PM
USA1C5
USA1C5's Avatar
Good point, I really didn't think about being more familiar with the track. Maybe next time I can do even better, although what top speed one can obtain on the longest straight is a small percentage of overall performance on a road course.
Old 11-20-2007, 08:04 PM
USA1C5
USA1C5's Avatar
Yes, I think you are correct CHJ In Virginia. Practice makes better I guess.
I think I remember you from Summit Point, Shenandoah Circuit. How's it going. I just did my last event for the year ar VIR. I don't expect anymore events until about Feb. or early Spring.
Old 11-20-2007, 08:34 PM
Z Fast
Z Fast's Avatar
Location: Bend, Oregon Black / Ebony 2LZ 2006 Z06 C6Z06 owner since 2/7/2006
Originally Posted by USA1C5
...... more familiar with the track. Maybe next time I can do even better...
We can all always do better. If we truly can't, then we either need a faster car or it's time to move onto another track
Old 11-20-2007, 09:16 PM
jrz1
jrz1's Avatar
slightly modified '06Z best per GPS around 163. Headers/intake/tune & suspension.
Old 11-20-2007, 09:33 PM
USA1C5
USA1C5's Avatar
With those mods my 155 in a totally stock C6Z all the way down to the tires sounds good to me. I was going to shoot for 160 next time but that's probably out of reach for total stock. When I say total stock I mean total stock, no tune, factory air filter, oem tires etc.
Old 11-20-2007, 10:00 PM
John Shiels
you do get to a point where trying to shave time or decrease lap times gets harder and harder as it drops. I guess that is the fun of it.
heavychevy
heavychevy's Avatar
I'd think the back straight speeds are least important. And if yo uare taking the time to look right before braking . If you concentrate too much on the back straight speed you will end up overshooting the braking zone (Assuming you arent coasting for a while). Fastest back straight speed does not equal fastest lap.
Just my opinion.
Old 11-20-2007, 10:12 PM
USA1C5
USA1C5's Avatar
Just my opinion.
You are correct. As I said earlier in this Thread, what top speed one can obtain on the longest straight is a small percentage of overall performance on a road course. It is a good measure of how one gets out of Oak Tree. As far as watching speed, that can be done with a GPS device that records top speed. The only drawback to mine is at the end of track session it only records top speed of entire session so you don't know what lap but you know where you did it at VIR because theres only one straight I could do that.
Old 11-20-2007, 10:48 PM
Timz06
Timz06's Avatar
Totally stock z should be over 160- depends on your exit out of oak tree.
Tim
Old 11-20-2007, 10:52 PM
USA1C5
USA1C5's Avatar
Tim
I'm totally stock. Who is correct ???
Old 11-20-2007, 11:12 PM
JDIllon
JDIllon's Avatar
7000RPM in 4th Gear=161 thats my best on the VIR back straight. Tough to get into 5th on that staight. JD
Old 11-20-2007, 11:22 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Few run stock tire sizes on the track. One would have to calculate very closely the actual adjusted speed of the vehicle to compare one vehicle with another. Running 305's on the rear of my Z (see mods in sig) I realized best of only 145 mph my one trip there. Of course, my TB was acting up and went into "limp home" mode as I rounded Oak Tree my last lap. So, I probably wasn't 100% that day when it was half way working.
Old 11-21-2007, 04:15 AM
John Shiels
depends greatly on driver equation,
To 155 mph @ VIR back straight
Old 11-21-2007, 05:20 AM
varkwso
varkwso's Avatar
Tim
JD left foot brake for the tree and you will get into 5th no problem in a C6Z there..
Old 11-21-2007, 05:35 AM
94ZR1#444
94ZR1#444's Avatar
I could only squeeze out 162 or so and was no where near 5th gear. I had stock pads on and anything faster would definitley be a Code Brown....
Old 11-21-2007, 06:26 AM
varkwso
varkwso's Avatar
brakes only slow you down...
Quick Reply: 155 mph @ VIR back straight
