camber kit vs eccentric
it would still be adjustable. you adjust it with shims, not the eccentric. i remember doing alignments on old GM musclecars back in the day and using only shims. just like you do when you get a camber kit.
i think the biggest deal with the camber kit is that you can get more negative camber than stock -- the eccentric replacement on the lower a-arm puts the bottom of the tire out further than the widest setting of the eccentric. then you dial it in on the upper a-arm with shims.
but the nice side effect is that the camber doesn't change over time.
it actually seems cheaper to me to use fixed parts rather than an eccentric, and just wondering why the general doesn't do this from the factory.
YMMV.
Frank Gonzalez
However, when working on your own car, you can find the settings that work for you and keep them. You can also move easily between race and street settings by changing a few notches/shims and setting the toe. This does not require an alignment/check each time.
I'm also sure the eccentric bolt assembly is much cheaper to make than an assortment of lower shims. Plus, each owner would need to purchase shims to work on their own car and alignment shops would need to stock the lower shims as well. The aftermarket solution, for the maybe 5% of us who care, is much better.
--Dan
