scatter shield for road racing?
Old 12-11-2007, 11:20 AM
MattB
Support Corvetteforum!
MattB's Avatar
Default scatter shield for road racing?
My first thought is 'No', but then again I don't know too much. Is a scatter shield a good idea? I need to buy a bell housing, so its not just an upgrade...
Thanks,
Matt
Old 12-11-2007, 11:49 AM
Independent1
Independent1's Avatar
St. Jude Donor '08
If you are using an aluminum flywheel you should get a scattershield in case your flywheel decides to self-destruct. They have a habit of splintering when they go and you don't want to get hit by the scrapnel.
If you have a steel or light-weight steel flywheel you can probably get away without a scattershield.
Old 12-12-2007, 01:33 PM
MattB
MattB's Avatar
Thanks for feedback, interesting point, had not thought of an aluminum flywheel. I'm looking to get a billet steel one
I assumed that scattershields were for 1/4 mile guys who really abuse their clutch and not so much for road race where you don't want the rear tires braking loose in a turn...
Any other opinions?
Old 12-12-2007, 01:46 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
A missed downshift can blow a clutch just as well.
I just wish there was a ZF scattershield.
The blankets work, but they hold heat & oil.
Old 12-12-2007, 01:47 PM
mpowers
mpowers's Avatar
It is a requirement for NASA road racing. I am sure SCCA is the same and others will chime in.
Old 12-12-2007, 03:22 PM
63Corvette
63Corvette's Avatar
Default Blown flywheel story
At a vintage race at Green Valley raceway near Fort Worth in October 1984, Carrol Shelby drove a race Cobra owned by Rick Nagel. During the race the flywheel of a Shelby GT350 Mustang blew up just as Shelby was passing him at the end of the drag strip front straight. The flywheel explosion took out the entire hydraulic system of the Mustang, and a 4 lb piece of shrapnel went theough the left front cowl of Carrol Shelby's Cobra, and through the driver's compartment, missing him by inches.
Yes, I would (do) run a scattershield.
Old 12-12-2007, 05:08 PM
Jeffvette
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Blankets are a POS. I also didn't think they were rated for manual trans cars. Just autos.
Old 12-12-2007, 08:30 PM
mrc24x
mrc24x's Avatar
Really?? Is that new or did I miss it??
Old 12-13-2007, 11:13 AM
BrianCunningham
NCCC makes you run a blanket with a ZF for GroupIII
What's TCC run? or for that matter what did the WorldChallenge C4's run?
Old 12-13-2007, 11:53 AM
wallyman424
wallyman424's Avatar
yeah, i'm pretty sure its not a req.
Old 12-13-2007, 12:04 PM
eogel
eogel's Avatar
No specfic requirement for a scatter shield in TCC.
Old 12-13-2007, 12:29 PM
mpowers
mpowers's Avatar
My bad, not required in the ccr but is required for my class. I was thinking it was a ccr requirement.
Old 12-13-2007, 01:05 PM
MattB
MattB's Avatar
Another good point, blown shifts. Makes me think I should get one.
A blanket sounds like a fire waiting to happen
Old 12-13-2007, 01:08 PM
wallyman424
yeah, i figured as much.
Old 01-02-2010, 11:36 PM
96solo
96solo's Avatar
Where can you buy a good blanket and scatter shield without getting your wallet cut up too?
D.J. Covert
Old 01-03-2010, 12:25 AM
drivinhard
drivinhard's Avatar
http://www.quicktimeinc.com/products.html
Old 01-03-2010, 12:32 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
I have a scatter shield in my 2001 SW Z06. It's made by Quicktime and RPM Transmission sells them.
If your clutch ever exploded or suffered some kind of catastrophic failure it could literally kill you in the vette since the floors are made out of balsa wood and thin aluminum sheet.
Also all of your major wiring harnesses run along that area and if they suffered damage your car would be probably be totaled.
D.J. Covert
RPM Transmission sells them for around $450.
To scatter shield for road racing?
Old 01-03-2010, 12:36 AM
drivinhard
drivinhard's Avatar
there was a thread on CF years ago where a guy's C5 clutch let go. lots of pics. the majority of the pressure plate went up through the dash and through the windshield.
there was a guy at road atlanta about 2-3 yrs ago that lost a leg on a clutch explosion
Old 01-03-2010, 01:47 AM
Olitho
Olitho's Avatar
Originally Posted by drivinhard
It looks like this unit weighs about 22 lbs for the C5 if I read that right.
It is still questionable legality in something like SCCA T1 I imagine, not to mention the weight being undesirable. But safety is a good thing, too.
SFI Certified @ 6.1
RM-6035 - Chevy LS Bellhousing/97-04 Corvette manual
Height = 5.786
Trans. Bore Ø = N/A
Engine = Chevy LS-1, LS-2, LS-3, LS-6, LS-7, LS-9
Trans. = 97-04 C5 Corvette manual
Clutch Ø = 11"
Flywheel = 168 tooth or 153 tooth
Weight = 22#
Full engine plate and grade 8 bolts included
Old 01-03-2010, 03:54 AM
rustyguns
rustyguns's Avatar
D.J. Covert
holds too much heat !!!!!!!!!
Quick Reply: scatter shield for road racing?
