Best "Race" Type Seat w/ Stock Seat Belts
Old 12-16-2007, 01:02 PM
mwvettec5
mwvettec5's Avatar
Default Best "Race" Type Seat w/ Stock Seat Belts
Sorry, I know seats have been discussed hundreds of times but after reading a number of threads I have come to no conclusions.
What is the best seat choice for better support than stock C6 seats ???
A seat that can be mounted so the airbags work, the seat can be adjusted and the stock belts can be used ???
THANKS in advance for advice and pictures
Old 12-16-2007, 02:07 PM
Silverton
Silverton's Avatar
Recaro Pole Position. More money: Caravaggio Corvettes.
Old 12-16-2007, 05:30 PM
gkmccready
gkmccready's Avatar
Caravaggio keeps all the electronics happy. $1395 ea.
http://www.caravaggiocorvettes.com/d...ther_Seats.pdf
The other adjustable option might be similar to what I did in my RX7, which is MOMO seat rails, then mount on those. But in the Corvette you'll have to be pretty short to pull that off...
Old 12-16-2007, 08:42 PM
Silverton
Silverton's Avatar
The electronics are no longer a problem. Just call Pfadt Racing and order one of their connectors.
Old 12-16-2007, 10:23 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Old 12-24-2007, 01:58 AM
GettReal
GettReal's Avatar
How much are the pole positions and are you saying you can keep the power options on the recaros? I was looking at Caravaggios but would love to keep the power with something cheaper.
Old 12-24-2007, 05:33 PM
niteriderc5
niteriderc5's Avatar
jsut remove the seat motor harness and reconnect it to the base of the floor, and it should fit snug under your aftermarket seat.
Worked just fine on the C5 w/ sparco Rev
To Best "Race" Type Seat w/ Stock Seat Belts
Quick Reply: Best "Race" Type Seat w/ Stock Seat Belts
