Tire Temperature Monitoring
http://www.ioportracing.com/Merchant...egory_Code=NEW
Probably a little late for Christmas now...
The brand new Opti-Grip tire temperature monitoring system is everything racers have been dreaming about. It’s a simple, affordable system that allows a driver to monitor his real-time tire temperatures. Until now, this technology has only been available to large budget race teams. The system uses 4 small infrared sensors mounted in the wheel wells. An easily mountable LCD screen displays large easy-to-read temperatures. The system also includes a memory recall button mountable near the steering wheel.
# System includes: 1 LCD Screen
# 4 IR sensors with replaceable lenses
# 15-foot mini USB cables
# 1 Junction box
# 1 Power adapter
# All mounting hardware
# 1 Junction box
# 1 Power adapter
# 1 Junction box
# 1 Power adapter
# 1 Junction box
# 1 Power adapter
http://racecartesting.com/products.html
Non-Contact Infrared Temperature Sensor
Allows Real-Time On Board Monitoring of Tire Temperature. Just Imagine the possibilities!
Mount 3 per tire for Outside, Middle, Inside. Tune for optimum camber and air pressure settings where it matters - In the CORNERS!
A bunch of years ago, I went to a chassis setup seminar that had the pro setup ( 3 sensors on each tire ). Very educational, tire temps change rapidly.
I see guys at the track bring their cars off the track, into the paddock, take some time to get out of thecar, get a drink,etc. and then take tire temps (worthless) with an infrared pyrometer (also worthless).
This is a neat product but, as noted, you really need 3 sensors per tire to tell you what's really going on. It would also be nice if it could store complete laps. But,that would drive the price way up.
Former Vendor
Suggestion, not as nice as accross the tread on all four but mount 2 per front tire, 3 if you must, get that one setup, then move to the other one or other pair(rear), etc.
This should help a great deal on initial setup and individual track setup then use them where needed during a race.
Or, get two systems, three, etc. starts getting a bit costly though.
Rick
Rick
Rick
Rick
Former Vendor
Yes it would take allot of time but I thought of another option. Sensors may be cheap, mount and wire them (the wire will not weigh that much, maybe a phone cable will work or CAT5) and mount a switch that will select the tires individually. A switch that opens the contacts completely before it moves to the next position may be a good idea
Rick
Rick
