Fuel Safe fuel cell questions...
Old 12-23-2007, 01:36 PM
BlackRocket
BlackRocket's Avatar
Default Fuel Safe fuel cell questions...
What size fuel safe fuel cell fits in a C4???
I have the current Fuel Safe brochure and all their 15 gal tanks are 18" deep; (front to back). The stock fuel tank is only 12" deep. There is enough clearance between the brake light housings and the rear cockpit panel for 15-16"...but not 18"
The only way I can see making the 15 gal Fuel cell work is to cut the rear fiberglass drop panel since it will need clearance towards the front. Also, where would the fill neck be centered...Under the rear hatch glass???
Thanks for any/all info you can spare on this one!
Old 12-23-2007, 09:50 PM
0Vector Vette
Former Vendor
Vector Vette's Avatar
Contact Dave Wehlie at Melrose T-Tops. He has a complete system for the C4 including an ATL 22 gal fuel cell, mounting bracket, fuel pump and filter. It is a complete bolt in system, all you have to do is run the fuel lines.
Robert
Old 12-23-2007, 10:58 PM
eogel
eogel's Avatar
I have the 22 gallon ATL cell and setup Vector Vette described above. Replaced the steel fuel cell can this summer with their aluminum one. Did all of the work in my garage. The Melrose cage holding the fuel cell bolts to the rear of the C4 body. Removing the rear bumper makes the work easier.
Ed
Old 12-23-2007, 11:58 PM
cnewman57
cnewman57's Avatar
What did this kit cost?
Old 12-24-2007, 01:03 AM
0Vector Vette
Former Vendor
Mine has been in the car for so long that I don't remember for sure. It is probably best to contact Melrose for a current price.
Robert
To Fuel Safe fuel cell questions...
Quick Reply: Fuel Safe fuel cell questions...
