Will a Sparco Evo seat fit in a C4??
Does anyone know if a Sparco Evo seat will fit in a 94? It came out of a 2002 ZO6. Do you know if I will need to purchase different mounting hardware?
Thanks for your help.
Kevin
Kevin
It is a tight fit but yes. If you are short enough you can bolt the sparco side mount brackets to your power seat frame. Otherwise you may want to use the hardbar mounts.
