Some engine porn pictures
Former Vendor
Some engine **** pictures
2) 427s, one of them will be drysump with LS7 heads and intake. The other one is running very well ported set of aftermarket LS6 heads and Harrop intake.
1) 412 with LS6 heads and a mangacharger 122.
A couple more engines in the works!!! A few more in the engine room and we could build a tractor puller
More pictures coming soon!!!
Randy
www.dougrippie.com
What cars are they going in C6 C6Z C5? Looks great keep the pictures coming!
I use to do my 4-stroke motorcycle mods years ago at my friends shop. Doubt I would tackle a car engine would be nice but I'll stick to beating on them with a pedal.
Former Vendor
All of them should be done by the end of the week! Then in comes the next projects
Randy
Former Vendor
I'm sure Doug would show you how to lap valves. After 28 years of lapping valves, he would love someone that would do it for him. Every valve gets lapped by hand, checked for spring installed heights (.005), flow benched, deburred, pressure checked, milled, every spring is tested at 3 different heights, every cam gets checked. Some shops only check a few and pray the rest are right, not around here. Doug will not let that happen even if the time is running out on a project.
I worked in the engine shop for about 6 years total of my life. One year when I was about 13 years old. Then when I was about 19 or so. Then a 3 year from 2000-2003. It was a great!!! I learned from Doug, and his friends, like uncle Jack and Grandpa. After that I have been running the mail order and holding down the office. They still give me crap about when I dropped a engine off the stand when I was 13 My knee still hurts to this day. They give me crap about falling asleep in the drivers chair at 3:30 AM bleeding brakes and filling the tranny and diff.
Randy
www.dougrippie.com
Randy
www.dougrippie.com
Former Vendor
Take a look at this one
NASCAR LS2 Motor
PP 243 heads, Comp 281 rollar cam and almost 600 HP Up 8000 rpms.
NASCAR LS2 Motor
Former Vendor
The oil soaks into the roller bearings. It helps with the first startup wear and tear. How long does it take to get the neddle bearings soaked in a fresh engine, the answer is too long!
Most of the engines get put on the engine dyno for the first start up and break in, cranking with no sparkplugs.
Randy
Randy
Former Vendor
NASCAR LS2 Motor
NASCAR LS2 Motor
Randy
Former Vendor
Here are a couple more pictures!!! These are pistons from about 2 years ago. I'm too much of a racer to show you todays pistons. But they are all coated now, every piston installed into a engine at DRM is coated. Also a picture of a C5R block in the hone tank! This flowbench has had more heads on it then I can remember. Every head gets checked!!!
I also saw the lastest issue of Corvette Mag, with our testing on the new Z06. Go to your local news stand and pick up a copy!!!
Nothing better then a heavy piston spinning at that RPM. I think the Nascar name is over used. The Nascar engine today are way trick, this engine doesn't seem that trick. 8000 rpm is small displacement way of making power. Big bore and stroke engines pull and don't need the rpm to make it happen.
Randy
Randy
What dry sump are you using??
Former Vendor
