AC Winch?
Old 01-18-2008, 05:32 PM
mousecatcher
mousecatcher's Avatar
Default AC Winch?
After seeing the discussion about power req'ts for a winch, I'm thinking why don't I get an AC powered winch? My tow vehicle (toyota tacoma) has an AC plug on the back.
Old 01-18-2008, 06:16 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I bet most are 12 volt. may be look at industrial suppy for some type of AC winch in Grainger .
Old 01-18-2008, 07:35 PM
c4cruiser
c4cruiser's Avatar
Why not just install a dedicated battery on the trailer and connect the winch leads to it. Get something like an Optima Yellow Top or similar deep-cycle battery. Get one with the highest ratings you can find and install a marine battery box on the trailer for the battery to sit in.
You can use the tow vehicle to re-charge the battery or simply use a small battery charger when you get home.
Old 01-18-2008, 08:42 PM
mousecatcher
most winches (that i've found) are 12 volt. but AC powered ones do exist. i already have one in my garage actually.
i figured by getting an AC winch i wouldn't have to bother installing a battery and charging it, etc.
Old 01-18-2008, 09:20 PM
Falcon
Falcon's Avatar
Are you sure the inverter on your truck has enough amperage to run the winch. That would put a big load on the the wiring and the inverter.
Old 01-18-2008, 09:23 PM
mousecatcher
the sticker on the truck outlet says 400W. what is that in amps?
Old 01-18-2008, 09:40 PM
mousecatcher
i think that's 3.3A. If that's right, it's well under the capacity needed. DC it is.
To AC Winch?
Quick Reply: AC Winch?
