Goodridge or StopTech brake lines..
Any big difference between the two? I'm changing rotors and pads and thought that would be a good time to change the lines as well. I'm using Motul RBF 600
I think the StopTech lines have a clear tube over the stainless braid. That may prevent dirt from getting past the braid. I'm not sure if this is a big issue or not.
From StopTech's web site:
StopTech brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing.
I don't know if the others have the cover or not.
Former Vendor
1 Post
Until you put some serious miles on your stock brake lines, there is no significant performance gain in switching to braided lines.
Our braided lines also have the layer cover over the stainless braid that resists abraision.
We usually stock them in two colors. Red and Smoke.
St. Jude Donor '10-'11
Usually, someone responds with the suggestion to get -AN fittings vice banjo fittings and pick lines based on that.
I wanted covered lines when I went to SS in '05 ... and got StopTech with Banjo ends because I couldn't / didn't find -AN with covered lines ATT. CW is still with -AN but the StopTech's have been fine.
I had Goodridge S.S. brake lines with my stock calipers, until I did the Wilwood upgrade. I like them, easy to install, and pedal feel was good. I can't compare to the others, but would recommend the Goodridge based on my experience with them.
Goodridge has been selling faulty SS line kits for Evolutions for years now, but they are still selling the kits. You have to call them and request the correct fittings after you find out they do not seal properly in the rear. If that isn't shady I don't know what is. I will never buy another product from them ever again.
Oh yeah I own an Evo.
I have the goodridge lines on my 03. Ever since they were installed I feel like the pedal is not as good as it should be. I have double and tripple checked all the connections are good. I finally found that the left rear was wet. I have since pulled the fitting off and re-installed it. They feel alot better but still are not the "super firm" pedal that I expected. Guess I will have to upgrade the calipers to get that feeling.
If I were to buy another set I would be getting the stoptech lines.
Supporting Vendor
Spiegler lines are the highest quality lines available today. We have them for the C5, C6, and C7. They are a bit more expensive than the other brands mentioned, but they're still cheaper than a set of brake pads. They're made from Swiss and American components, and fully assembled and tested in Ohio. They have a cool swivel feature on the fittings that allow you to install them without tension and twisting, a clear abrasion coating, extremely hard fittings that won't deform like butter when you wrench on them, etc. You can see details on our site: Spiegler Stainless Steel Brake Lines for Corvettes
JRitt@essex (03-12-2020)
