ferodo pads
Old 01-21-2008, 09:55 PM
CodeBlack
CodeBlack's Avatar
Default ferodo pads
Can anyone point me to a source for OEM pads "ferodo DS2500" other than a chevy dealer or suggest a pad that is similar to ferodo's. I struck out on the internet Car is a C6Z06 with stock calipers and rotors. Will be running a few track events as a new guy this year.
Old 01-21-2008, 10:12 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
should have titled it "Race pads for stock C6Z06 calipers?" some will chime in soon.
there are 3-4 choices I think. See what Frank G. uses or Matt.
Old 01-21-2008, 10:14 PM
John Shiels
http://forums.corvetteforum.com/sear...archid=7212834 some info in here
Old 01-21-2008, 10:33 PM
CodeBlack
CodeBlack's Avatar
Originally Posted by John Shiels
Thanks John but when I tried it it said no match. I'm trying to find a pad with a similar compound to oem. with all the info on the forum I'm on over load mentally
Old 01-21-2008, 11:32 PM
Cloaked323
Support Corvetteforum!
Cloaked323's Avatar
I searched for those pads last year my search met with negative results. If you find them please post the location
Old 01-21-2008, 11:46 PM
CodeBlack
CodeBlack's Avatar
Will do, everyone I spoke with including vendors from the forum stated that DS2500's are being kept with the GM dealers for the C6Z06. any pads out there that you guys have used that are similar that wont chew up the rotors that can be used for a novice at a few track events or is there no such thing? I've done a lot of reading from various companies about there compounds but I rather stick to the knowledge of the forum's race section
Old 01-22-2008, 06:50 AM
John Shiels
worked when I did it sorry. try searching in this or C6ZO6 forum "C6ZO6 brake pads" or "race pads" in the C6Z06 forum
Old 01-22-2008, 07:39 AM
AU N EGL
AU N EGL's Avatar
Essecs parts are the or one of the Fedaro importers
http://www.essexparts.com/
the web site is a bit dated.
Fedro catalog http://www.essexparts.com/CatalogPDF...-19_Ferodo.pdf
DS2500, DS3000, DS3000 plus and 4003 Motorsports are the pad compounds. You will also need the pad style
FPC1553, FCP1563 are the styles for the C5 and C6 calipers
The FCP1553 comes in DS2500 and DS3000
the FCP 1563 only comes in DS2500
If you know the style or pad number, plus the compound you want call Essex.
The are a BIG BIG Nascar parts supplier and the AP Racing Brake importer. I got some some thermal heat shield from them
Old 01-22-2008, 07:51 AM
John Shiels
he needs them for the C6Z06 OEM calipers what is the pad shape number?
Old 01-22-2008, 12:03 PM
Sidney004
Sidney004's Avatar
Why is the dealer stocking racing pads? It looks like a really nice compound:http://www.ferodo.co.uk/ferodo_home/ click under motorsports for pad details.
They make a DS3000plus03 that has a cf of .72
Old 01-22-2008, 01:11 PM
CodeBlack
CodeBlack's Avatar
An article in corvette quarterly, winter 2006 page 53 regarding the C6Z06 brake system stated that the car is equipped with PBR calipers, San Luis Rassini partners with brembo for the rotors and ferodo DS2500 pads
Old 01-22-2008, 03:00 PM
gonzalezfj
gonzalezfj's Avatar
Talk to Hawk and ask them for one of their softer compounds. For serious track use you need DTC-60 at least, although some of the beginners here use HP+ with good results.
Old 01-22-2008, 03:01 PM
gonzalezfj
gonzalezfj's Avatar
HB531 in Hawk-speak.
Frank Gonzalez
Old 01-22-2008, 09:30 PM
CodeBlack
CodeBlack's Avatar
Thanks for the help
To ferodo pads
Quick Reply: ferodo pads
