C5 seat mounting nuts
Old 01-22-2008, 08:31 PM
spazegun2213
spazegun2213's Avatar
Default C5 seat mounting nuts
Anyone know their size? its really close to 10mm x 1.5... maybe a 10mm x 2.0?
anyone know what size they are? I'd rather not have to go to the dealership for them but i may have to.
Old 01-23-2008, 12:18 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Pretty sure it's 10 x 1.5.
Old 01-23-2008, 01:03 PM
spazegun2213
its close to that, maybe 10-1.75, because it would not thread all the way down on a 1.5 bolt
Old 01-23-2008, 03:08 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
The stock nuts have some sort of locking feature. Like nylock or something. A regular 10 x 1.5 nut will run all the way down the stud.
Or, knock the studs out and replace them with longer bolts to make it easier to change the seats.
Old 01-23-2008, 04:43 PM
Last C5
Last C5's Avatar
A little more information on knocking the studs out please. Those short studs are a never ending problem when mounting seats, belts, etc.
Old 01-23-2008, 05:33 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Look under the car and locate the heads of the studs. I cut most of the weld off with a cut-off wheel. Then I took a socket, slightly larger than the head of the stud, and raised it up with a floor jack over the bottom of the stud to hold the floor stable, while allowing the stud to fall. Then take your BFH of choice, and whack the hell out of the stud from above.
Ta-da, you can now replace them with a longer bolt. I used some large washers to spread the force out under the car, and silicone to help seal it all back up and hold the bolt in place. Made swapping seats, rollbar, belts yada yada yada infinitely easier.
ckreider33 (03-19-2024)
Old 01-23-2008, 05:55 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Hardbarusa.com has an adapter to extend the studs which is easier than new bolts unless you are going to tack them back. I took mine out years back but replacing the seat is a PITA but I don't do it as it is permanent. If you do knock them out put some graded washer to help strengthen it.
http://hardbarusa.com/hardbar/produc...products_id=69
Old 01-23-2008, 07:26 PM
Last C5
Last C5's Avatar
Thanks guys, now I've got a couple ways to go when I want more available threads in the future.
To C5 seat mounting nuts
Quick Reply: C5 seat mounting nuts
