Autox'ers What do you use?
I had a local graphics/sign shop makeup a set of static-cling decals. The numbers are 8" high and the class letters are 6" high. The numbers are on a clear backer so when they are installed, all you see is the numbers.
Static cling is easy to install and remove and if you keep them clean, they will outlast the removeable vinyl adhesive decals.
You can also find number sets and assorted graphics at SoloTime
Reusable vinyl from iZoomGraphics. Set of three numbers for both sides of your car for only $26. I used one set for ten events and removed them after each event.
Static Clings. Any sign shop can make them. Cost in the
30.00 - 40.00 range for 6"-8" numbers. Spray mixture of water and a small amount of wash liquid on car and affix day prior to event. They'll adhere at any speed and rain wont take them off. Pull off and reapply to backing for next events use.
Static Clings. Any sign shop can make them. Cost in the 30.00 - 40.00 range for 6"-8" numbers. Spray mixture of water and a small amount of wash liquid on car and affix day prior to event. They'll adhere at high speed and rain wont take them off. Pull off and reapply to backing for next events use.
I've used everything over the years. Static cling, reusable vinyl, blue tape, and reusable bumper film. They all work for the intended purpose.
Now I use static cling from solotime.com for my usual local events where I have a year long number and for nationals so the car looks good for all those pictures!
I carry blue painters tape for those non-local events (Porsche club etc.) when they assign you some screwy number and some class letters that you've never heard of...what is XM1, and why am I now running in the same class as Mark Daddio?
And I carry reusable bumper film from the office store, and a pair of scissors for those emergencies where the number blows off or I need a quick number 1 for a co-driver.
But in short, anything that the course workers can see is just fine.
Good luck.
Good luck.
Static cling for me, made at a local sign shop. 8" vinyl numbers on a clear sheet have lasted for five years autocrossing. I stick mine on dry, just clean the door surface and the back of the numbers, and put a strip of blue 3M electrical tape on the leading edge.
This picture is from the first year I had them, but they look 95+% as good now as then:
Here's a bit fuzzier picture from last year:
HTH, and have a good one,
Mike
Mike
I bought a roll of blue painters tape at the begining of the season and it lasted me the whole year. Granted may not look as great but dose the job. This next year i'm thinking about just putting vinyl Numbers and class on since about the only time i get to run the car is for AX or Road raceing granted i know the numbers are permanit but i have some found some white tape to match the car not to mention i'll have some extra strips of vinyl made up to make some diffrent letters.
Go to Wal-Mart and get a roll of shelf paper in the color you want. It will stick fine and come off with out a problem when you want it to. I stick it on a piece of plexe when I'm done with it and it last for about 5 events then I just make more. I'll get 2 to 3 years out of 1 $8 roll.
Dave
Dave
