8Ft Tie down straps/Webbing only Where to get??
Old 01-26-2008, 04:19 PM
Brett Richmond
Brett Richmond's Avatar
Default 8Ft Tie down straps/Webbing only Where to get??
I need to find the 8ft straps for my car, I only need the strap and hook only, not the ratchet part as I have those from my other straps that I already have. I have looked at Northern Tool, Lowes, Home Depot and even Harbor Freight and no one has them at all. Any ideas as Jegs does not seem to stock just the strap part, either on-line or a chain would be good for me as I will need these in the next 3 weeks. The straps I have are 20 and 30 ft long which is way to much excess to mess with on the vette. Any help would be appreciated!!!
Old 01-26-2008, 04:24 PM
rbl
rbl's Avatar
If you wife or you can sew and has a machine you can cut them to length and sew the hooks back on using 10# test nylon fishing line.
I made mine and use them with the Vette and SRF. They have many thousands of miles on them and just keep on working.
Northern tool has the hooks.
Old 01-26-2008, 06:53 PM
Quacker
Quacker's Avatar
You'll find it here
http://www.awdirect.com
To 8Ft Tie down straps/Webbing only Where to get??
Quick Reply: 8Ft Tie down straps/Webbing only Where to get??
