HAWK DTC-70/60 for C6 Z06 Track Use?
Old 02-01-2008, 06:23 PM
Dicecal
Dicecal's Avatar
Default HAWK DTC-70/60 for C6 Z06 Track Use?
I think I'm going to use these pads on my Z06 for track use. Looking for feedback, positive or negative, before I purchase them. Or any other suggestions.. Thanks in advance!
Old 02-01-2008, 06:56 PM
kentz06
Support Corvetteforum!
kentz06's Avatar
I used the DTC-70/60 with the stock calipers/rotors to good effect. Also went to 70s in the rear to see if more braking effort could be generated. Not certain if it helped, but it didn't hurt control either.
They did consume the stock rotors quickly. StopTek two piece rotors were an improvement. High temp brake fluid, SS brake lines and front rotor air ducts are inexpensive and helpful.
Dean
Old 02-01-2008, 07:25 PM
Dicecal
Dicecal's Avatar
Dean
Thanks Dean. I have SS lines, 2 piece Slotted Stop Techs on the Front and slotted DBAs on the rear with Motul Fluid. I have Porterfield R-4 pads, but some people have complained about them trashing the rotors, so I'm looking for another pad. Anyone else?
Old 02-01-2008, 08:51 PM
gonzalezfj
gonzalezfj's Avatar
I have used DTC-70 pads exclusively in my C5Z and now in my C6Z. Over 4 years with no problems. You will like them.
Old 02-01-2008, 09:18 PM
JDIllon
JDIllon's Avatar
I used 70s/60s before going to BBK and they worked well. Next best thing to BBKs, and the slotted rotors will help with the rotor life. JD
Old 02-01-2008, 09:27 PM
stano
stano's Avatar
Have you looked into the CarboTech XP12's? I was told they work well with the DBA 4000 rotors.
Old 02-01-2008, 09:38 PM
JDIllon
JDIllon's Avatar
Old 02-01-2008, 10:30 PM
Dicecal
Dicecal's Avatar
Frank, DTC-70s on all corners..or 70s front / 60s rear?
Old 02-02-2008, 01:14 PM
gonzalezfj
gonzalezfj's Avatar
Usually DTC-70 all the way around. One time I got a set from JDillon that was 70 front, 60 rear. I could not tell any difference vs. my usual set-up.
Frank Gonzalez
To HAWK DTC-70/60 for C6 Z06 Track Use?
Quick Reply: HAWK DTC-70/60 for C6 Z06 Track Use?
