Springs, can they be too stiff?
St. Jude Donor '03 & '05
Seems to me, everything stock is not stiff enough, along with shocks.
SO my question is, when does a spring become to stiff in autoX?
Do you want the spring to allow some lean, and let the alignment and tires do the rest?
Former Vendor
I am new to the Vette scene but pretty experienced in autocross with all types of drivetrains and have always preferred moderate springs, adjustable sway bars and the fattest, softest tires I am allowed to run in the class.
Plenty of negative camber, positvie caster, probably some tow out front and rear, may be the way to go, have not had the change to test yet, not for a few months here in Utah.
So, just general thoughts for now, more into track days and building up to road race now but I will run autocrosses because I like them and I can get my kids more involved(the main reason, keep them off the streets, teach them to really drive
Whatever you do, use light wheels!!!!
Rick
Rick
When it won't let you utilize all of your suspension travel in the conditions you normally drive/race in I would imagine. I thought my springs were to stiff in my track car so I put zip ties (some people use rubber bands) on my shock shafts & after the track day looked to see how much travel was used. Even with a wheel rate of 495lbs. it used it all. So I felt good about my set-up.
Former Vendor
Yes, zip ties, etc, very good testing tool
Softer springs can help keep the tires on the ground on rougher surfaces, bumps, etc, more contact, more grip, more speed
To soft, bottom out, lose grip and other issues.
There is a more accurate but more time consuming way to determine optimal spring rates, damper settings, etc. it has to do with frequency, I will address that once the season gets rolling.
Rick
Rick
Rick
Rick
i have a picture of what too much rear spring can do...
http://gallery.floridacorvetteracing..._0703_173604AA
there are a lot of factors that will dictate the required spring rate, but in my case i had WAY too much spring, and it made the rear "loose", so when i tried to turn a little too fast in a slalom, the rear came around on me. ended up down a hill then up a tree... but i did learn a lot. got a softer spring from VBP, and now the car is much more competitive. (so, the body panels are different colors now, at least i washed the berry stains off...) http://gallery.floridacorvetteracing...all05/IMG_1068
Hey Sam,
Are you guys doing the Tampa Fairgrounds this year? When is the next time you're running a sanctioned event at Brooksville?
Joe T
North Florida Corvette Association
Zip ties are useless the second you hit a bump. If you drive on a perfectly smooth sheet of glass with zero jacking forces from the steering - then you can consider them a good tuning tool.
Springs are too stiff when the suspension looses the ability to remain compliant over bumps.
There is nothing wrong with lean. Load transfer is completely dependent on the dimensions of the car. Track width and CG height. The lower the car - the less load transfer - the lower the car - the stiffer the car needs to be to remain off the bumpstops.
All above sounds good. If you are driving on a laser-level-smooth surface, then maybe you could drive without springs. I used to see a lot of slammed hondas running around town with no springs in them. They BOUNCE around just like a track car would, with the tires literally leaving the ground every time they hit even the smalled bump.
Tires are springs also, and allow some compliance, and in an F1 car, I'd bet the tire is "softer" than the actual springs. However, in road cars, you want the suspenion to be compliant to bumps, the inside tires to droop in corners to aid in grip, and you want the weight to shift in a smooth controlled manner.
If you are driving on a smooth surface - you still have load transfer when you turn. I bet those Honda's had springs on them - I bet they were super soft, super low and way out of the operation range of the stock shocks they were using. Thats why they were bouncing around all over the place. There is a difference in bouncing because of a lack of damping and bouncing because there is no compliance in the suspension.
BTW - weight never transfers - it is always a downward component at the CG. The term you are looking for is "load transfer"
You shouldn't be using springs to control body roll. You control body roll with the sway bars.
Springs, shocks and sway bars all have different purposes. The real job of the spring is to keep the car from dragging on the ground. Today you really want the softest springs you can find - and the biggest sway bars you can locate.
On the other hand a Kuhmo engineer once told me that if I got the car totally screwed up and it became impossible to find the sweet spot just put stiff springs in it and "run it like a damn go kart." He said that stiff springs will cover up all sorts of bad settings.
I run the base springs in my '85 and Z51 bars. Bilstein made me up a set of custom shocks. Now if I can get more negative camber into the damn thing I'll be fine.
Richard Newton
Autocross Performance Handbook
Wheel and Tire Performance Handbook
Richard Newton
Even the spring rate on a Formula E is high. We run 600 and 1000 springs on an 1100 lb. car.
Davy Jones, from Indy cars, did some testing on these cars when we changed to Penske shocks and said he was supprised how soft the cars were, so you know the Indy cars are extremely stiff.
So soft springs, big sway bars and custom shocks with plenty of camber and sticky tires. Stiff springs arent doing you any good?
Then why does everyone use a ZO7/Z51/ZO6 etc. Just get a base suspension, get big bars and an alignment?
Most of the ZO7/Z51/ZO6 cars are street cars. That's a whole different agenda.
Richard Newton
Richard Newton
Richard Newton
Richard Newton
hi joe - we have 10/25 & 10/26 reserved at brooksville. still trying to get back at the fairgrounds, and now we are talking to some people with a track in bradenton. if they get their zoning straight we might be able to do something there earlier in the year. i was going to try and get an early date at brooksville, but due to a miscommunication we didn't. we will have some non-sanctioned events there starting back up in may.
steve - i don;t remember exactly, but i think gary said it was 750#/in - seems there were some mislabeled springs at vette brakes. gary took care of me though, and got me the right spring - and it made a big difference. i think the new spring is maybe 350#/in. not only do i stay on the track now, i noticed almost 2 second improvement on a ~50 second autocross course. that was at the fairgrounds, and the course was the same. i could be way ff on the #'s, i would have to check with gary.
you want the stiffest possible spring, to control dive and squat. you want the softest possible sway bar, because the stiffer the sway bar (which only exists to make up for inadequate springs) the more bumps in a corner upset your handling (by transferring energy to the opposite wheel).
in a street car, you give up too much in ride quality if you use springs that are too stiff, so you have to compromise with sway bars.
formula cars have very little sway bar. some none at all.
just as an example, if you add more rear sway bar, the car gets looser. this is because more load is transferred from the outer wheel (where the grip is) to the inner wheel.
of course my advice is worth what you paid for it.
