Recommend a Camera & Mount
Old 10-24-2008, 12:22 PM
RoganR
RoganR's Avatar
Default Recommend a Camera & Mount
I'd like to load up a camera on the outside of my car for a road course event. Is this allowed? And if so, please recommend me a setup. I have a camera, but the sound is horrible b/c of all the wind noise.
Old 10-24-2008, 12:47 PM
sperkins
sperkins's Avatar
You want it on the outside?
I almost bought one of these:
http://www.goprocamera.com/
Old 10-24-2008, 01:49 PM
RoganR
RoganR's Avatar
great link...thanks.
you didn't buy just b/c or you got something else?
Old 10-24-2008, 02:24 PM
sperkins
sperkins's Avatar
I did a lot of research back in the spring and at that time they were having problems with some type of radio interference causing horrible audio buzz. Also, some of the units had bad optical sensors which caused a very fuzzy and bouncy picture. Do a YouTube search on the gopro and you can see for yourself. There are a lot of cool videos where guys have them mounted their radio controlled airplanes.
I have heard however that those issues have been resolved.
Old 10-24-2008, 06:01 PM
AZ FASTEST
Support Corvetteforum!
AZ FASTEST's Avatar
Default Professional Grade...........
Here's the stuff we used in the film industry, and I use on my car....
http://www.filmtools.com/carmounts.html
Look at the single suction cup mount and add a safety wire.
We use 500 pound test nylon covered deep-sea fishing leader wire with crimped connectors. Then loop the other end around a fixture under the hood. door, or hatch lid.
I've gotten approval from the NASA director with the safety wires in time trials.
Old 10-25-2008, 05:04 AM
RoganR
RoganR's Avatar
Old 10-25-2008, 05:06 AM
RoganR
RoganR's Avatar
Great info. I'd still need a better camera b/c off all the windnoise coming through my current camera. Or is there something I can do on the mic to reduce the amount of windnoise?
Old 10-25-2008, 07:50 AM
sperkins
sperkins's Avatar
You can try putting tape over the microphone. That seems to help mine. The other (and better) thing to do is to use an external microphone if your camera will accept one. I would do that, but my camera does not have a port for one.
Old 10-25-2008, 02:08 PM
MA ZO6
MA ZO6's Avatar
St. Jude Donor '13
I use this on the INSIDE of my windshield, works great to hold my mini DV camcorder.
http://www.chasecam.com/mounts/suction/SM30
John
Old 10-25-2008, 07:28 PM
racerbob4
racerbob4's Avatar
Take a look at www.cam-fx.com They have anything from one to 4 cameras and glass suction cup mounts to roll cage mounts. Its a nice system, we have the two camera set-up and can now look forward or backward. Sometimes you want to see who hit you from the rear as well as what you are doing on the corners from the front.
Old 10-25-2008, 08:24 PM
NemesisC5
NemesisC5's Avatar
Thanks for sharing, it looks like a nice setup I'd like to hear some opinions comparing this to the Chasecam setup?
Old 10-25-2008, 08:56 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Here's my Hardbar camera mount:
and some of the vidoes I've taken:
http://www.youtube.com/profile?user=...od&view=videos
To Recommend a Camera & Mount
Quick Reply: Recommend a Camera & Mount
