C4 Dual Rear Springs?
Old 10-26-2008, 08:11 PM
rfn026
rfn026's Avatar
Default C4 Dual Rear Springs?
This is soemthing I've never seen before. This is on a BSP SCCA car. I suspect it has something to do with the rule book but I'm not sure.
Why the dual springs?
Richard Newton
Old 10-26-2008, 09:18 PM
StealthLT4
StealthLT4's Avatar
interesting. Maybe he couldn't find a stiff enough spring?
Old 10-26-2008, 09:32 PM
rezenclowd3
rezenclowd3's Avatar
Oooh, I like the roll center adjustments!
Old 10-26-2008, 11:20 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Looks like someone took a base spring and a Z07 spring instead of just going out and getting a new one.
Old 10-26-2008, 11:50 PM
Slalom4me
Slalom4me's Avatar
I would be VERY interested in seeing the outer ends of the springs.
Is there any chance that you happen to have a photo?
Old 10-27-2008, 12:20 AM
Slalom4me
Slalom4me's Avatar
Found them.
The outer attachment is different than I imagined might be the case.
It seemed possible that the purpose in part might be to create a
rising spring rate. In my mind's eye, I pictured a way the end
attachment might contribute to such a goal. However, the
pictures show that the ends are joined more in a more simple
manner - not one that I feel would contribute to creating RR.
The way the gap is maintained between the springs through the
centre section where they are fastened to the Bat Wing might
lead to a rising spring rate, though.
Old 10-27-2008, 05:49 AM
rfn026
rfn026's Avatar
Here's a shot of the outer end.
Richard Newton
Old 10-27-2008, 12:41 PM
the blur
the blur's Avatar
That must ride real nice on the street..
Old 10-27-2008, 01:10 PM
astock165
astock165's Avatar
You might be surprised. If the bottom spring is softer and the spring ends can move independantly, I'd suspect that the softer spring handles most of the suspension travel on the street and for those large travels you'd then get into the 2nd spring when you really needed it. With a good set of shocks this would be interesting to try.
Originally Posted by Slalom4me
Found them.
Are you referring to a "rising spring rate" as the same thing as a "dual rate spring"?. To me a "dual rate spring" is where two coils are stacked on top of one another and you get the combined spring rate until the bottom coil binds and then you get the single rate from the upper coil.
If not, can you describe "rising spring rate"?
The real trick would be to get this setup on the FRONT!
To C4 Dual Rear Springs?
Quick Reply: C4 Dual Rear Springs?
